Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #1
Noone
NY
None
Hi.. I am having a big problem with a 2002 LONGTRAC 360 DTC tractor. Underneath the gearbox of the Tractor there seems to be a 12 mm hole without any threads for any screws. Some Fluid seems to be leaking from the hole... I have attached 2 pictures of the hole. Can someone please help.. I need to know how to clog this and with what? There is nothing on it in the manual.
Thank you
http://i918.photobucket.com/albums/ad21/Darlok2000/Tractor/IMG_0111_zpscf91bfb1.jpg
http://i918.photobucket.com/albums/ad21/Darlok2000/Tractor/IMG_0112_zps4604d0c3.jpg
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #2
Looks like a open drain hole to let water and leaking oil (engine and tran) out so no built up.
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #3
Google "threadless 12mm pressure plug". An expandable plug is all that I can think must have been there? Can't be a vent or overflow since it's on the bottom of the trans case.
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #4
So what was the mystery hole.
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #5
I don't think you want to plug it. I think it's there to let water that condenses in the bell-housing and oil that gets past the rear seal have a place to escap, like ozley described. Plug it and you may rust up your clutch or contaminate it with oil. I'd just poke a piece of wire in there and make sure it isn't clogged whenever you do your regular maintenance on the machine.
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
