Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #1
Noone
NY
None
Hi.. I am having a big problem with a 2002 LONGTRAC 360 DTC tractor. Underneath the gearbox of the Tractor there seems to be a 12 mm hole without any threads for any screws. Some Fluid seems to be leaking from the hole... I have attached 2 pictures of the hole. Can someone please help.. I need to know how to clog this and with what? There is nothing on it in the manual.
Thank you
http://i918.photobucket.com/albums/ad21/Darlok2000/Tractor/IMG_0111_zpscf91bfb1.jpg
http://i918.photobucket.com/albums/ad21/Darlok2000/Tractor/IMG_0112_zps4604d0c3.jpg
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #2
Looks like a open drain hole to let water and leaking oil (engine and tran) out so no built up.
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #3
Google "threadless 12mm pressure plug". An expandable plug is all that I can think must have been there? Can't be a vent or overflow since it's on the bottom of the trans case.
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #4
So what was the mystery hole.
   / Need Help: Weird hole under the gearbox of my 360 LONGTRACT DTC Tractor #5
I don't think you want to plug it. I think it's there to let water that condenses in the bell-housing and oil that gets past the rear seal have a place to escap, like ozley described. Plug it and you may rust up your clutch or contaminate it with oil. I'd just poke a piece of wire in there and make sure it isn't clogged whenever you do your regular maintenance on the machine.
2011 Toyota Corolla (A55758)
2011 Toyota...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
CAT 973 (A47384)
CAT 973 (A47384)
2025 Swict 78in Bucket Skid Steer Attachment (A55787)
2025 Swict 78in...
