Disc Harrow Need help to ID this harrow disc
   / Need help to ID this harrow disc #1
Matt need help
None known
   / Need help to ID this harrow disc #2
That's gonna be a tough one. A LOT of companies produced discs over the years. Are you needing parts or just want to know what you have?
I want to rebuild it, need good parts
   / Need help to ID this harrow disc #4
I deal in them old implements. I have never had one they can't sell me parts for. Just measure the bearings, axle, disc, hubs, whatever you want. Make that call to a parts place. There's a 14' disc I'm pondering now. I bought a baler from him already.
   / Need help to ID this harrow disc #5
I was able to buy gang bearings at O'Reilly's. Wheel bearings would be the same.
Discs, just need to take it apart and confirm center hole design/size, then determine diameter of disc you need.
Keep us posted on your progress!!!
   / Need help to ID this harrow disc #6
ASC had all the bearings and assembly plates I needed to rebuild a 8 foot set of Long brand harrows..
As mentioned remove a section and take measurements of everything..
Axle length
Diameter
Bearing outer and inner
Assembly plate size and bolt pattern..
Spool lengths
End spacers..
I went with Brazilian made blades . Don't fall for the cheaper Indian made ones.. the sand will literally cut grooves in them.. ask my friend about that .
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2022 CATERPILLAR 259D3 SKID STEER (A52709)
2022 CATERPILLAR...
2007 Chevrolet Silverado 1500 Pickup Truck (A56858)
2007 Chevrolet...
Hydraulic rail grinder (A56436)
Hydraulic rail...
KODIAK 6' ROTARY MOWER (A52708)
KODIAK 6' ROTARY...
CATBKTSSL_78 (A55787)
