Disc Harrow Need help to ID this harrow disc
   / Need help to ID this harrow disc #1
Matt need help
None known
   / Need help to ID this harrow disc #2
That's gonna be a tough one. A LOT of companies produced discs over the years. Are you needing parts or just want to know what you have?
I want to rebuild it, need good parts
   / Need help to ID this harrow disc #4
I deal in them old implements. I have never had one they can't sell me parts for. Just measure the bearings, axle, disc, hubs, whatever you want. Make that call to a parts place. There's a 14' disc I'm pondering now. I bought a baler from him already.
   / Need help to ID this harrow disc #5
I was able to buy gang bearings at O'Reilly's. Wheel bearings would be the same.
Discs, just need to take it apart and confirm center hole design/size, then determine diameter of disc you need.
Keep us posted on your progress!!!
   / Need help to ID this harrow disc #6
ASC had all the bearings and assembly plates I needed to rebuild a 8 foot set of Long brand harrows..
As mentioned remove a section and take measurements of everything..
Axle length
Diameter
Bearing outer and inner
Assembly plate size and bolt pattern..
Spool lengths
End spacers..
I went with Brazilian made blades . Don't fall for the cheaper Indian made ones.. the sand will literally cut grooves in them.. ask my friend about that .
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE SKID...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
40' CONTAINER (A57192)
