Need help on sheeting a garage.
   / Need help on sheeting a garage.
WELL, I found the problem, the whole Garage does slope to the rear, by about 3/4" in three feet. Explains why water always went to the back of the building. Floating slab, built around 66. I would love to cut a trench in the concrete, to divert any little amount of water but much of my stuff has wheels or I use a pallet truck.
SO, what does one do? Still try and build and mount everything plumb inside? And deal wth the headaches of adjusting every sheet?
   / Need help on sheeting a garage. #22
Pound a drain hole in the outside wall and let it drain onto the ground, if possible. Adjusting every sheet is NOT a big deal. Measure and cut it off.
   / Need help on sheeting a garage. #24
this is how I hope to eliminate the water on floor soaking into the wall covering.
So this looks like my 2-storey shop, where the structural concrete walls were poured first with footings that go some distance down, then the floor slab was poured afterwards. In the photo, was this 3-4" high concrete "plinth" instead formed and poured on top of the previously poured slab?
Chris
The two sheets are done and actually much higher than I had planned off the floor on account of the screwups. A little better than 3/4", just enough to catch the 2x4 plate.
   / Need help on sheeting a garage. #26
You can cut a drain and put one of those metal grates over it. There smooth somewhat and use them in shops. Then divert to real drain or turn to the outside of building
I would love to do that, but have too many other projects that need to be done first. So I will just have to keep an eye on the ice and water situation.
   / Need help on sheeting a garage. #28
Sounds like the water is going to be an ongoing issue and there isn't a good solution to stop it from happening. Water and wood, drying and getting wet again, will create mold. Lots of it!!
If it was my place, I would install PVC trim of some kind on the floor, next to the sill plates. I would buy whatever is cheapest. I think Lowes has some solid white PVC 1x2 trim. I would put down a thick bead of flashing sealant, or something that is designed to water proof your floor. Is it concrete? Caulking and silicone would not be an option.
Then I would run another bead at the edge of the PVC on the ground an use my finger to make sure that it's solid so no moisture could get under it.
Then I would cut the OSB and install it on top of the PVC. I would probably pt the cut side at the top and use the factory cut side on the bottom.
   / Need help on sheeting a garage. #29
I'm sure your concrete is porous so even thou water may not seep thru or under the PVC, it is capable of going thru the concrete. Depending on how much area is affected, you could also pour a layer of self leveling concrete in the low section to change the way the water flows.
As long as you can get the water out quickly the concrete won't absorb much. It's also possible to seal the concrete to reduce the water absorption.
   / Need help on sheeting a garage. #30
I was thinking the same on self leveling. Unless like you said the area prohibits this. Or 2000sqft for 3/4" like you said. That would be a TON of self leveler
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
(APPROX 25) UNUSED LANDHONOR PINS (A54757)
(APPROX 25) UNUSED...
Long 35 Tractor (NOT RUNNING) (A50775)
Long 35 Tractor...
2007 Amkus Rescue System (A55787)
2007 Amkus Rescue...
kids dirt bike (A53424)
kids dirt bike...
