Loader Need Help! My BX25 Loader will not go back on!
   / Need Help! My BX25 Loader will not go back on! #31
:eek::eek: Agreed, don't ever do that.
I actually remove/install mine on uneven ground better than half the time, it just takes a bit of practice and maybe the occasional shim to get it right back on, I do this with my 2660 and 5030, but yes it is easier to do on a hard flat surface.
Glad all is well with your tractor.:thumbsup:
I agree. My pain the the **** backhoe pins...Pain in the behind to install the pins..
   / Need Help! My BX25 Loader will not go back on! #32
Well, my BX25 finally has a front end loader again! A local metal working friend straightened the left and right "Main Frame" parts and I managed to put both pins in the loader arms! I strongly caution all users to use a flat, even solid surface when removing their FEL. And never ever connect one pin and move the loader to a better spot by dragging the FEL. The long FEL arms and bucket weight will bend and twist things! But my FEL is now installed! :thumbsup:
Advice Well Taken......Sorry you had to learn this lesson....Glad it turned out OK......:thumbsup:
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
