Loader Need Help! My BX25 Loader will not go back on!
   / Need Help! My BX25 Loader will not go back on! #31
:eek::eek: Agreed, don't ever do that.
I actually remove/install mine on uneven ground better than half the time, it just takes a bit of practice and maybe the occasional shim to get it right back on, I do this with my 2660 and 5030, but yes it is easier to do on a hard flat surface.
Glad all is well with your tractor.:thumbsup:
I agree. My pain the the **** backhoe pins...Pain in the behind to install the pins..
   / Need Help! My BX25 Loader will not go back on! #32
Well, my BX25 finally has a front end loader again! A local metal working friend straightened the left and right "Main Frame" parts and I managed to put both pins in the loader arms! I strongly caution all users to use a flat, even solid surface when removing their FEL. And never ever connect one pin and move the loader to a better spot by dragging the FEL. The long FEL arms and bucket weight will bend and twist things! But my FEL is now installed! :thumbsup:
Advice Well Taken......Sorry you had to learn this lesson....Glad it turned out OK......:thumbsup:
2020 DRAGON ESP...
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2010 International Derrick Digger (A55973)
2010 International...
