Loader Need Help! My BX25 Loader will not go back on!
   / Need Help! My BX25 Loader will not go back on! #31
:eek::eek: Agreed, don't ever do that.
I actually remove/install mine on uneven ground better than half the time, it just takes a bit of practice and maybe the occasional shim to get it right back on, I do this with my 2660 and 5030, but yes it is easier to do on a hard flat surface.
Glad all is well with your tractor.:thumbsup:
I agree. My pain the the **** backhoe pins...Pain in the behind to install the pins..
   / Need Help! My BX25 Loader will not go back on! #32
Well, my BX25 finally has a front end loader again! A local metal working friend straightened the left and right "Main Frame" parts and I managed to put both pins in the loader arms! I strongly caution all users to use a flat, even solid surface when removing their FEL. And never ever connect one pin and move the loader to a better spot by dragging the FEL. The long FEL arms and bucket weight will bend and twist things! But my FEL is now installed! :thumbsup:
Advice Well Taken......Sorry you had to learn this lesson....Glad it turned out OK......:thumbsup:
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
flooring (A55758)
flooring (A55758)
2013 John Deere 824K Wheel Loader (A56435)
2013 John Deere...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
12' CONTAINER (A52706)
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
