Need help identyfing a part!
/ Need help identyfing a part! #1
Jchadbrown
Ford 8n
I took a part a 2 row disc and found this part busted. Can someone tell me what it's called? Can I get it replaced fairly easy?
/ Need help identyfing a part! #2
You need to provide a lot more info than that. It looks like a pic of one of the main "axles", but I'm not seeing anything busted.
/ Need help identyfing a part! #3
What is the make, model, year and if you cant get that maybe a picture of the whole unit would help people identify it
I cant see what is broken either
/ Need help identyfing a part! #4
Oh and btw were you working in a cave because it looks like ou took the picture in a cave:laughing::laughing:
/ Need help identyfing a part! #5
Like the others need more info! also what did you take off(picture of). also clean off the sourding dirt to see if that is a sleve on the shaft or part of the shaft. Was it a bearing point or what??????????:confused:
/ Need help identyfing a part! #7
It is a spool for a bearing setup. There should be 2 clamshell halves that go around it? What brand disc harrow is it? Ken Sweet
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
SCAN TO RECEIVE TEXT UPDATES (A63291)
SCAN TO RECEIVE...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
