Need help identyfing a part!
/ Need help identyfing a part! #1
Jchadbrown
Ford 8n
I took a part a 2 row disc and found this part busted. Can someone tell me what it's called? Can I get it replaced fairly easy?
/ Need help identyfing a part! #2
You need to provide a lot more info than that. It looks like a pic of one of the main "axles", but I'm not seeing anything busted.
/ Need help identyfing a part! #3
What is the make, model, year and if you cant get that maybe a picture of the whole unit would help people identify it
I cant see what is broken either
/ Need help identyfing a part! #4
Oh and btw were you working in a cave because it looks like ou took the picture in a cave:laughing::laughing:
/ Need help identyfing a part! #5
Like the others need more info! also what did you take off(picture of). also clean off the sourding dirt to see if that is a sleve on the shaft or part of the shaft. Was it a bearing point or what??????????:confused:
/ Need help identyfing a part! #7
It is a spool for a bearing setup. There should be 2 clamshell halves that go around it? What brand disc harrow is it? Ken Sweet
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
