Need help identyfing a part!
/ Need help identyfing a part! #1
Jchadbrown
Ford 8n
I took a part a 2 row disc and found this part busted. Can someone tell me what it's called? Can I get it replaced fairly easy?
/ Need help identyfing a part! #2
You need to provide a lot more info than that. It looks like a pic of one of the main "axles", but I'm not seeing anything busted.
/ Need help identyfing a part! #3
What is the make, model, year and if you cant get that maybe a picture of the whole unit would help people identify it
I cant see what is broken either
/ Need help identyfing a part! #4
Oh and btw were you working in a cave because it looks like ou took the picture in a cave:laughing::laughing:
/ Need help identyfing a part! #5
Like the others need more info! also what did you take off(picture of). also clean off the sourding dirt to see if that is a sleve on the shaft or part of the shaft. Was it a bearing point or what??????????:confused:
/ Need help identyfing a part! #7
It is a spool for a bearing setup. There should be 2 clamshell halves that go around it? What brand disc harrow is it? Ken Sweet
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
LOADER MOUNT HAY SPEAR (A63291)
LOADER MOUNT HAY...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
429860 (A61166)
429860 (A61166)
Amadas SPC-6 (A64119)
2022 EZ-GO ELITE...
