Need help identifying this line John Deere 310A backhoe
   / Need help identifying this line John Deere 310A backhoe #1
xcursion88
lx172, 8n, lo boy, mits backhoe
What us this line. It's leaking at the fitting.
A part number would be great
My finger is on the fitting that leaks
It runs to the bottom of the fuel tank I believe
   / Need help identifying this line John Deere 310A backhoe #2
Tee fitting that you have your finger on is on the fuel return line that leads back to "top of fuel tank". I think I located the correct seal(item 3) part # R51936 if your tractors serial range resembles SN in photo below. Seal on top of injector is part #R79605. Item 1 in 2nd phot is fuel return line to tank.
   / Need help identifying this line John Deere 310A backhoe #3
Welcome again to TBN
If Tx Jim has helped as it looks like he has, will you respond with what you do with that help? Tx Jim is a great resource for JD folk on TBN, as he has a lot of real experience and knowledge.
You did not give a response to your 2018 quest for help. Always nice to hear back as it helps others who may have a similar problem.
I'm not one to bail after starting a topic on a forum.
I'll take your word for it if you're saying I did that on here 7 years ago...
Something must have come up that distracted me from the forum.
I will be looking into his response to me as soon as I can get to the machine. (Around 4:30 p.m. EST)
At that point I will re-engage in this thread.
Hopefully you can see it.
This ends in a "T" so Im not sure this is the correct serial number...
It is on the engine. Right side.
Upon further review of the line it does indeed go to the top of the tank.
Thank you much for the ACCURATE and quick response !!!!!!
   / Need help identifying this line John Deere 310A backhoe #6
You're welfcome
Number on tag on engine is the engine serial # not model serial#
You're welfcome
Thx for that.
By that serial number on the engine do you think the part# you presented will work?
Thx
   / Need help identifying this line John Deere 310A backhoe #8
Sorry I forgot that the thread I posted listed engine serial # range. Yes I think part #s I posted should fit your tractors fuel system.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
19008 (A56859)
19008 (A56859)
