Need help hooking up backhoe attachment
/ Need help hooking up backhoe attachment
Thanks Arc weld
I've owned a couple of backhoe attachments that were on my skid steers but this is my first tractor and first time putting a backhow attachment on a tractor. I know the backhoe needs about 6 to 8 GPM so I'm hoping the tractor will supply enough for it. If for some reason I can't get it to work right on the tractor, I've been thinking about making it a towable BH since I have an engine and all I would need is a 8gpm pump. But, I hoping once I get the coupling I need and hook it up it will work. I have my fingers crossed anyway.
Thanks again!!
/ Need help hooking up backhoe attachment #12
To compute GPM.
A good trick is to put a clean milk jug in the 5 gal bucket, and time the 1 gal first.
Time the hyd flow from a hose in a 5 gal bucket and you will know the GPM at full engine rpm. Use the port /hose that you will use with the BH.
If you can flow 5.0 gal------30 sec = 10 GPM
If you can flow 5.0 gal------1 min = 5 GPM
If you can flow 1.0 gal----- 10 sec = 6 GPM.
If you can flow 2.0 gal----- 10 sec = 12 GPM
Ok, I'm back working on my backhoe again, finally!!!! I got sick again and havn't been able to do anything for the last few weeks. I figured out the hydraulic lines and went and bought some tractor quick coupling and took off the ones that were on the backhoe. They were the type for a bobcat and it cost more for just one set (one male one female) than what I could buy 6 sets of the tractor type. I was able to mount the backhoe to my forklift setup, the only thing I had to do was cut off the part on the bottom on the backhoe attachment the the rod would go through when you push the lever down on a bobcat. The top slips right in the inverted v part on top just like a bobcat would. I then welded a piece of angle on each side and drilled holes through it and the backhoe so that I can use two 1/2" bolts on each side. That keeps the backhoe from lifting up or moving side to side. Then I used the original bobcat fasteners that fit in a u piece welded on the backhoe and extended them down to the reinforced lifting arms I have on the tractor. All that works great and is fairly easy to hook up.
Now my problem is, the backhoe is a lot slower than it should be. I have to make sure the lever on the hydraulic thing on the right hand side of the tractor where the lines go to the back of the tractor is all the way in and can't come out any at all or it will slow down even more or if it comes out to far, the backhoe won't work at all. I'm going to a grand opening of a new Tractor Supply in Bessemer Alabama in the morning and get new filters and hydraulic fluid. I hope that will help if not, then I don't know what to do. Would a power beyond port make any difference. I want to add another hydraulic lever so that when I'm not using the backhoe, I can replace my top link with a hydraulic cylinder, that way I can tilt my forks some and make picking up logs and setting then on the mill easier.
Any suggestions would be appreciated.
The backhoe will dig but like I said its kinda slow and doesn't seem to have the power it should. I've owned a couple of backhoes that were mounted on bobcats and this is the same size and type as the others I've had but right now something is just not right. I believe I saw in the manual the other day that the tractor is a 8gpm pump and the backhoe says not to use over 12gpm. While I'm not as concerned about speed as I am strength. I need to put a thumb on it to pick up end pieces, etc on logs since I'm no longer able to pick up much at all myself.
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2013 NISSAN NV3500 CARGO VAN (A59906)
2013 NISSAN NV3500...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2023 John Deere 325G (A60462)
2023 John Deere...
