Need help getting rusty grade 5 bolt out of stainless steel.
   / Need help getting rusty grade 5 bolt out of stainless steel. #21
Back in the dark ages I helped a bud with one like that. We ground the broken bolt flat, then drilled and tapped.
That’s never the best solution in my experience. Unless you over size, you’re all but guaranteed to drill/tap into existing threads, with partial old threads falling out and an oval shaped loose finished hole
I'm lucky I had enough if a stub to heat and then grip onto with a pipe wrench. Otherwise I would be trying to drill a part with a curve in it.
   / Need help getting rusty grade 5 bolt out of stainless steel. #23
I agree. Lately I would weld a nut onto a broken stud, even if the stud is flush to the piece around it, welding in the center of the nut to make good contact. Then I put a wrench on it and back the broken stud out. The welding heats up the stud and helps it to break loose and the nut gives you something to put a wrench or socket onto. If the weld breaks, grab another nut and try again.
   / Need help getting rusty grade 5 bolt out of stainless steel. #24
OK, soft flame however.
On these two broken off cap screws, I used a rock hard flame, reheated to red hot multiple times, and then welded on a nut to turn them out.
Welding on the nuts assured they were good and HOT ;-)
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
Mailbox (A55853)
Mailbox (A55853)
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
Toro Mower (A50324)
Toro Mower (A50324)
