Need Help Finding Snap Fastners
/ Need Help Finding Snap Fastners #1
Ragged Edges
Fultonville, NY
John Deere 4500, Massey Ferguson 35 Deluxe (Work in Progress Project)
Im in the process of refurbishing the frame on the curtis soft cab that is on my JD 4500 Compact. I purchaed new curtins and when I re painted the roof and lower front windsheld areas, I wanted to replace missing and damaged snaps studs that secure the curtins to the frame.
I found the snap fastner kits at the local hardware store but I have a couple of problems. First the screw type studs screws need to be a larger size to fit the existing holes. The ones that came in the kits I found were #8. I really need # 10's for them to fit correctly. Also, the screws are too long. The ones I was able to find were 3/8 . I really want something shorter so I dont have to cut them off and grind them down.
I have been looking on line but dont seem to find what I want. I also dont want to order anything and have it not work. Maybe someone else has done a similar project and could help me out finding these.
any help anyone could give me would be greatly appreciated. I expect my frame back from the fab shop soon and really need to put this back together before we get snow. I really dont want to plow without the cab!
Thanks,
Mike
/ Need Help Finding Snap Fastners #2
try a place that repairs boat tops or awning or tent repair or
uphostery stores
/ Need Help Finding Snap Fastners #3
I found them at Home Depot believe it or not. In the hardware section where all the nuts and bolts are they have 2 or 3 rotating bins marked specialty fasteners. May have to buy the ones designed to rivet on and use your own screws.
Brian
/ Need Help Finding Snap Fastners #4
Lowe's also has 'em. Item #: 308800.
I'll bet you can find them at West Marine if you have one near.
Do a search for "snap fastener kit" and you'll find tons of them.
/ Need Help Finding Snap Fastners #5
Tandy Leather is my suggestion for a large snap selection.
http://www.tandyleatherfactory.com/en-usd/Snaps.
Not sure where you are located (thanks iPhone app) but they have some retail locations. But their online catalogue is very helpful, and should let you know what setter is required.
Dean
/ Need Help Finding Snap Fastners #6
I bought some years ago at a boat cover place as suggested earlier.
/ Need Help Finding Snap Fastners #7
perhaps not quite your situation, but when I use a golf cart cover as a "cab", I have attached quite strong button magnets to it at strategic places, which cling tenaciously to the respective parts of the tractor...keeps things quite taut and, if I need to reach in, anywhere, it's easy to do ...more info available if req'd
/ Need Help Finding Snap Fastners #11
sailrite.com has a huge assortment
McMaster will be the cheapest if they have what you need
Perfect Fit Upholstery also has a lot of similar products.
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2017 Toyota Hybrid Pruis Hatchback (A61574)
2017 Toyota Hybrid...
