Need help finding a pto driven water pump.
/ Need help finding a pto driven water pump. #1
TerryJ
Far Western Kentucky(Ballard Co.)
Case IH JX80,Kioti DK45S
I'm looking for a 540 pto driven water/trash pump that has a minimum 500gpm discharge flow. I have found several new ones but they are very pricey for what they are. It will be used for field irrigation/flooding purposes. I would appreciate any and all help trying to locate one of these. Thanks to all in advance.
/ Need help finding a pto driven water pump. #2
Are you sure you are looking for 500 gallons per minute?
Andy
/ Need help finding a pto driven water pump. #5
Back in my oilfield construction days (1979-1985), we used pto driven pumps for various projects. The best brand we found was "Gorman Rupp" (and I'm not sure if that is the correct spelling).
I also have no idea as to their output, we used several different sizes. Our most common used an 8" hose for suction, and 6" hose for discharge. Because of their output, and dependability, they were always the most desired to take on a job. I honestly don't even remember the names of the other brands, After using a couple of the G/Rs, that is all we purchased.
Because of the abundance of water transfers around here, very many of the welding/machine shops make their own versions of irrigation, and trash/pit pumps; if you need, maybe I can look up a couple of phone #s.
GreenWannabe,
Yeah, something along the lines of the Berkley. Towed or 3pt. hitch would be ok.
/ Need help finding a pto driven water pump. #8
I don't know what your price range is but just to give you an idea, we repossessed one back in the late 80's. It was a small pull type Gorman-Rupp I think. It sold at auction for $1000.
/ Need help finding a pto driven water pump. #9
The ones that I could find on the internet with 500 GPM minimum sold in the range of $5,000 and up. Few post prices most want you to contact them.
Even a bare pump costs around $1500 and you would need to fabricate a drive system for it.
I'm looking at finding a used one for around $2500 hopefully. I have a 13hp honda portable with 4" inlet and outlet, pumps about 600gpm but need a pto drive model for more reliability.
/ Need help finding a pto driven water pump. #11
Buy an old fire truck; cheap and you will get a nice pump with not a lot of hours on it.
/ Need help finding a pto driven water pump. #12
Why would you want to tie your nice tractor to a water pump? So you can walk back and forth? Maybe you have a few spares...
The main reason for the pto pump is reliability. The place that it will be used to flood is a place that only a tractor or an atv can get to. The intention is to run the pump 24/7 until the flooding is finished, then add water as need to maintain level. And yes, I do have more than one tractor.
/ Need help finding a pto driven water pump. #14
TerryJ
After pumping many basements with the volunteer fire company you will have a problem with debris on the suction strainer.
We started using some home built jet pumps for low lifts an 8" piece of pvc sewer pipe with a rope through it with a fire hose from the truck tied to the hose fastened about 1 foot in side the lower end. These worked great for large areas were we didn't have to move around a lot.
We could run 3 or 4 of these with one truck it dose take pressure on the hose ~ 100psi but with one 1000gpm truck you could move 3-4000 gallons of water pipes passed the debris right through them (leaves and other small stuff)
We took suction for the truck off a area with less debris to keep the strainer clean
tom
Tom,
Thanks for the input, but debris is not a problem as I will be pumping from a clear running creek (some would call it a small river) with a mud/sand bottom. I pump from it now with a 4" Honda portable with no problems, strainer is supported about 1' off bottom. I just need something with alot more volume.
/ Need help finding a pto driven water pump. #16
I have a Hale pto pump 550 gpm on a trailer that will do the job for you.
Model 40FC9-5R550
It was originally used in an field irrigation system. Manually primed. Once it catches, get out of the way....
213097 (A64276)
213097 (A64276)
2004 Chevrolet C4500 Western Hauler Truck, VIN # 1GBE4E1294F517585 (A65563)
2004 Chevrolet...
2013 LAY FLAT REEL TRAILER (A65643)
2013 LAY FLAT REEL...
213324 (A64279)
213324 (A64279)
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
