Need help figuring out barn extension
   / Need help figuring out barn extension
Yes I was going to completely remove all off the siding and then reuse it for the walls on the extension.
   / Need help figuring out barn extension #32
H.K. Porter makes a flush cut (flat blade) bolt cutter that I have used for similar jobs. The Amazon price is about $27.
http://www.armstrongtools.com/h-k-p...sh-cut-blades-and-plastic-dipped-handles.html
Those might work. Regular end nippers or hoof nippers won't cut nails. Knipex has some that will cut nails and piano wire. Should work.
https://www.jbtoolsales.com/knipex-...MI372u-9aA1wIVT1mGCh1p-w9SEAQYAiABEgK6IfD_BwE
Wish I had found them when I was trying to salvage some tin.
   / Need help figuring out barn extension #33
I'd use my 4.5 inch grinder with a cut off wheel on the nail heads.
I was about to suggest a grinder. It seems a grinder would be tedious to keep from cutting into the metal. Looks like he has lead head nails so some breathing protection might be needed?
   / Need help figuring out barn extension #34
Here to tell you huys that old time nail puller i posted does a surprisingly good job.
   / Need help figuring out barn extension #36
I'm sure it did. Those are good at pulling nails.
If you were pulling the nails did you get any damage to the siding?
Put a board under the part of the tool against the siding and you will have very little damage. The one timed i used one years ago i was amazed.
   / Need help figuring out barn extension #37
Agree on the board to protect the metal.
Does that have a hammer slide on it? Hardware store near me had something like that. Had something to grip on one end and a hammer slide on the handle.
   / Need help figuring out barn extension #39
The one I used did not. You use just like a claw hammer, the difference, those jaws clip under the nail/screw head, and the more you pull the more it tightens. You can put some real pulling force that way. It just flat works.
Enclosed Service Truck (A55788)
Enclosed Service...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
White Metal Roof Panels (A55758)
White Metal Roof...
Ford 8510 (A53317)
Ford 8510 (A53317)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 Ford F-250 (A55973)
2012 Ford F-250...
