>>> NEED HELP CHOOSING PUMP <<<
/ >>> NEED HELP CHOOSING PUMP <<< #1
BearKiller
Hi.
Tractor is a 1972 Mitsubishi R2500 2-cylinder diesel.
It has a previous-owner installed front-end loader that has a belt-driven pump.
The 4-bolt mounting bolt-pattern is 2-inches square.
The top pressure fitting that connects to the control-valves is 3/8-NPT.
The bottom low-pressure fitting that connects to the bottom of the reservoir is 1/2-NPT.
The shaft on the existing pump is a very short 7/16 diameter,
The existing 7/16-bore V-belt pulley has wallowed out it's bore and is un-usable; alas, I have searched in vain for a 7/16-bore replacement.
As I can't find a 7/16-bore V-belt drive-pulley to fit my existing pump, I am considering buying a new pump that has a more common shaft-diameter, such as 1/2 or 5/8.
When I looked at the pump selection at Surplus Center, I was overwhelmed at my ignorance about hydraulic pumps.
They list them by cubic-inch ??whatever?? and there are hundreds of choices.
Then there are two-stage, single-stage, and many other options.
Can someone enlighten me as to what I need ??
I ??think?? the one I have is ContraryClockWise, as it faces the opposite direction to the engine.
Thanks. :)
/ >>> NEED HELP CHOOSING PUMP <<< #2
How many GPM's do you need, and what pressure is the current pump?
My Power-Trac uses this 3 GPM/3000 psi pump for the steering and the lift. With 2, 2 in cyl, it will lift 1800 lbs. It is V belt driven off the engine. They make this pump in a larger size, and I will find you one that will work. Shaft size is 1/2 in. CW rotation looking at the shaft.
Which way would the pump have to turn if mounted like an alternator?
https://www.surpluscenter.com/item.asp?item=9-4199&catname=hydraulic
https://www.surpluscenter.com/item.asp?item=9-7788-B&catname=hydraulic
I have no idea whatsoever.
There are no identification markings that I can see.
The loader is fully hydraulic, with down-pressure.
The bucket is at least three healthy wheel-barrow-fulls and it will raise it full of #5 limestone with authority.
It will easily raise the front wheels several inches using down-pressure.
The opposite direction.
I really appreciate this. :)
Okay, this is the CW pump that you (J J) found :
https://www.surpluscenter.com/item.asp?item=9-7788-B&catname=hydraulic[/QUOTE]
This should be the same pump, except CCW :
https://www.surpluscenter.com/item.asp?item=9-7788-D&catname=hydraulic
According to my feeble descriptions, is this pump capable of meeting my requirements ??
I like that they also have seal-kits on hand.
I.D. sizewise, how does the SAE-12/SAE-10 compare to my 1/2-NPT IN, 3/8-NPT OUT ??
What would be the center-to-center of the 2-bolt SAE mounting pattern ??
Many thanks. :)
/ >>> NEED HELP CHOOSING PUMP <<< #5
Which way does your engine turn looking at the fan?
Can you show a picture of the engine and pump.
I will look again tomorrow in daylight; but, I am almost certain that the engine rotates Clock-Wise the same as all the rest of the various engines around the place.
I am not smart enough to do pictures. :(
The hydraulic-pump rotates opposite to engine rotation, just like the one bolted onto the immediate front of the tractor,coupled to the crank-shaft, that powers the 3-point hitch lift-arms. :)
I just had a close look at the engine and, according to the pitch of the fan-blades, the engines turns Clock-Wise; thus, the loader pump must turn Counter-Clock-Wise.
Thanks. :)
BUMP TO THE TOP 1234567890
/ >>> NEED HELP CHOOSING PUMP <<< #9
G'day you can get a taper lock pulley and bore the centre parallel then machine a sleeve with the correct size bore and then press in and weld, have done this a few times myself with good success, would have to be cheaper than a new pump i'm guessing.
Jon
2013 Caterpillar Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
2013 Caterpillar...
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
PALLET OF CULTIVATOR PARTS & FERTILIZER APPS. (A64278)
PALLET OF...
CAMMOND 10' BOX BLADE ON WHEELS (A64278)
CAMMOND 10' BOX...
