ME83
I had recently purchased a TG1860G garden tractor that has a problem (got it really cheap). Every so often it would stall. It has an 18 hp liquid cooled Kawasaki engine with the hour meter reading 187 hrs.
I cleaned the gas tank out and installed new fuel line & filter. It is not the fuel cutoff selonoid since it has power to it when and after it stalls (therefore not a safety switch problem). Sometimes it will run for a while and sometimes for only a minute tops. The fuel pump is weeping a little bit of fuel from a weep hole in it, I assume this means the diafram is cracked and I need a new fuel pump?
One other thing is there is a vacuum line coming off of the top of the carb. It is a clear small tube, where is this suppose to go? The other end got melted by the muffler and I cannot find where it goes.
Any help is appreciated.
