Need computer help? Call TBN !
/ Need computer help? Call TBN ! #1
gotrocks
Platinum Member
Phenix City Alabama
B-2910 delivered 8/23/01
Hello,
Been off for a while but would like some suggestions, please.
Got a question regarding speed of computer.
When I win a game of the OLD solitaire and the cards start to "peal" off, the speed is s-l-o-w,
BUT if I start moving the mouse in a rapid motion the card speed increases at least 2 or 3 times faster.
Anyone have any idea what causes this, AND can I change some setting to make things faster ALL the time?
Here a shot of the screen in question.
/ Need computer help? Call TBN ! #2
Odds are you need to add some ram to your computer. Any idea of the amount you have? For the price of Ram right now for computers of your assumed vintage you'll be kicking yourself you didn't upgrade sooner.
/ Need computer help? Call TBN ! #5
I never win so I've never seen what happens at the end.
Same here. Never have won that game. I gave up after trying to win the darn game 100 times.
Chad
/ Need computer help? Call TBN ! #6
I thought it always did that.
It does, at least on the 5 PC's I've had.
As far as "RAM" upgrading can do wonders, but find out for sure the limit and the correct style before you order. For instance Win xp or 7 in 32 bit will hold much more ram (in the slots) than the processor can use ( believe it is 3mb), on a 64bit pc you can use much more RAM.
/ Need computer help? Call TBN ! #7
I think 32 bit XP will recognize a little over 3 GIG (not meg) of RAM. Some older machines only had 500 meg...you'll definitely notice a difference if you upgrade from that.
64 bit Win 7 will recognize more, but to realize the full potential you need 64 bit versions of your software too. Unless you're doing video editing or heavy-duty graphics it's probably not worth it.
/ Need computer help? Call TBN ! #8
Yep, ~3.5GB usable IIRC
I think that if I were buying a new computer, I would go for 6GB of ram. I can use that now (only need 3GBish though) and it will certainly be needed down the road.
Aaron Z
/ Need computer help? Call TBN ! #9
i just ordered a new laptop, 8 gig ram, 1TB hard drive,, oi,, can you imagine filling that up?
thought that about 40 gig 10 years ago,,,
:D
/ Need computer help? Call TBN ! #10
The operating system you are running for RAM is secondary. What matters is your motherboard and what type (SIMM, DIMM, DRAM, etc.) of RAM it accepts and what speeds and sizes it will accommodate. Many newer motherboards use RAM in multiples of two to get better performance. Mixing older, slower RAM with newer, faster RAM is a waste of money. All RAM on the motherboard should be of the same speed. As with all plastics, older motherboards do have a tendency to crack if you are not careful pulling RAM out and putting RAM in. If you have a brand name computer like Dell or HP you can go to crucial.com, put in your information on the computer brand and model number to see what may work and what type it accepts. If you have a locally built computer, your motherboard was probably made by one of the larger companies like Gigabyte, Intel, Asus, Biostar, etc. You can open up the case and get the motherboard brand and model off the board if you do not have a manual for the board. Be sure to discharge any static electricity before messing with your board.
/ Need computer help? Call TBN ! #11
Has it always performed this way?
You didn't mention what else may be running while you're playing etc...you can download apps for finding and fixing memory leaks...
open the device manager and find the running processes and see what "might" be hogging RAM....
for instance...if you are running anti virus software...try killing the process and see if it makes any difference (you can disconnect the Internet connection while your shields are down)
/ Need computer help? Call TBN ! #12
Norris, I don't know the answer to your question, but as a veteran of many games of solitaire with actual cards while in the US Navy, I never thought of terms used to describe the game. I don't think I ever knew the names until I looked it up. I've listed some questions below. If you scroll down the page, you'll find the answers.
1. What is the name of the most widely played solitaire game?
2. When you deal the cards into seven columns on the table at the beginning of the game, what is that called?
3. The deck is placed above the columns on the left side. What is the stack to its right where you place cards face up?
4. When you turn up an Ace, you place it into one of four positions at the top-right of the playing area. What are these stacks on the Ace called?
V
V
V
V
V
V
V
V
V
V
V
V
1. Klondike Solitaire
2. The columns are called the tableau.
3. The stack beside the deck is called the waste.
4. The stacks with the Aces are called the foundations.
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
PENDING SELLER CONFIRMATIONS (A59911)
PENDING SELLER...
Claas Lexion 450/460/465 Combine Service and Parts Manuals (A63117)
Claas Lexion...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2014 Mitsubishi Outlander Sport SUV (A61574)
2014 Mitsubishi...
