Need Air Compressor and Bench Grinder advice.
   / Need Air Compressor and Bench Grinder advice.
I know But i like the 175 for the air blow gun, I guess I could have a by pass for a full pressure hose and then a regulated hose.
I am not sure what size teh out let threads are on the IR Compressor.
   / Need Air Compressor and Bench Grinder advice. #53
I would try 90 PSI first and then work your way up. 175 PSI is a bit much.
   / Need Air Compressor and Bench Grinder advice. #54
Tractor Supply will know. They should be able to "kit" your compressor. I would think that they would have regulators also.
They seem to have cheap 1/4 NPT Regulators in stock, I looked around today.The outlet is either 3/4 NPT or 1/2 NPT I think it is 3/4
   / Need Air Compressor and Bench Grinder advice. #56
You are buying on heck of a compressor. You won't be disappointed. Close to mine in size but yours has much more CFM. I would say 1/4" NPT fittings. Maybe even 3/8" NPT. I doubt 1/2" NPT or 3/4" NPT. Regulators are not high tech. They either work or they don't.
   / Need Air Compressor and Bench Grinder advice. #57
If the new Ingersol Rands are built as well as the old ones you will really like the new compressor, I use 2 1987 models of the 5 hp 60 gallon vertical type for auto body tools/garage use and so far the tools haven't been able to out run the compressors combined output of 22cfm@90psi :)
Also other than oil changes, draining water and cleaning the air filters neither has ever required ANYTHING
definitely run your standard air tools at around 90 psi -running at 175psi will void the warranty and could cause (catastrophic) failure of some.. Enjoy the new compressor:thumbsup:
   / Need Air Compressor and Bench Grinder advice. #58
i''ll Prob pick this one up this week, Now I need Regulator help, I can' seem to find a decent one, I would like it to adjust to the full 175 PSI this Compressor will put out.
Ingersoll Randョ 5HP Air Compressor, 80 gal. - Tractor Supply Online Store
Actually the pressure switch on most compressors will be set to just below the rated pump pressure (cut out pressure) then once the pressure drops a certain amount they re-start the compressor(cut in pressure), and some compressors come equipped with a regulator after the pressure switch, right from the manufacturer. Neither of my Ingersols had the regulator though...
   / Need Air Compressor and Bench Grinder advice. #59
If you don't turn the adjustment knob to change the regulated pressure fairly often, you have problems with it when you need it the most. When I had a 60 gallon compressor, I had a regulator I could take apart, clean, and re-install. And with the 30 gallon compressor I currently have, the regulator died recently, so I bought a new one. But instead of installing it in the usual way, I put quick connectors on it, and of course have a quick connector at the compressor so I can unplug the hose and put the regulator on anytime. But normally I'm just using the compressor's full power of about 150 psi without the regulator being inline.
I may put a t in line, so I'll have the reg on one out put and a full power port. I use 1/4 NPT Fittings, but the threads off of the compressor ball valve is 3/4 Thread I think.
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2018 Honda Odyssey Van (A56859)
2018 Honda Odyssey...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2021 Troy-Bilt TB110 21in Push Mower (A55973)
2021 Troy-Bilt...
