Need Air Compressor and Bench Grinder advice.
   / Need Air Compressor and Bench Grinder advice.
I know But i like the 175 for the air blow gun, I guess I could have a by pass for a full pressure hose and then a regulated hose.
I am not sure what size teh out let threads are on the IR Compressor.
   / Need Air Compressor and Bench Grinder advice. #53
I would try 90 PSI first and then work your way up. 175 PSI is a bit much.
   / Need Air Compressor and Bench Grinder advice. #54
Tractor Supply will know. They should be able to "kit" your compressor. I would think that they would have regulators also.
They seem to have cheap 1/4 NPT Regulators in stock, I looked around today.The outlet is either 3/4 NPT or 1/2 NPT I think it is 3/4
   / Need Air Compressor and Bench Grinder advice. #56
You are buying on heck of a compressor. You won't be disappointed. Close to mine in size but yours has much more CFM. I would say 1/4" NPT fittings. Maybe even 3/8" NPT. I doubt 1/2" NPT or 3/4" NPT. Regulators are not high tech. They either work or they don't.
   / Need Air Compressor and Bench Grinder advice. #57
If the new Ingersol Rands are built as well as the old ones you will really like the new compressor, I use 2 1987 models of the 5 hp 60 gallon vertical type for auto body tools/garage use and so far the tools haven't been able to out run the compressors combined output of 22cfm@90psi :)
Also other than oil changes, draining water and cleaning the air filters neither has ever required ANYTHING
definitely run your standard air tools at around 90 psi -running at 175psi will void the warranty and could cause (catastrophic) failure of some.. Enjoy the new compressor:thumbsup:
   / Need Air Compressor and Bench Grinder advice. #58
i''ll Prob pick this one up this week, Now I need Regulator help, I can' seem to find a decent one, I would like it to adjust to the full 175 PSI this Compressor will put out.
Ingersoll Randョ 5HP Air Compressor, 80 gal. - Tractor Supply Online Store
Actually the pressure switch on most compressors will be set to just below the rated pump pressure (cut out pressure) then once the pressure drops a certain amount they re-start the compressor(cut in pressure), and some compressors come equipped with a regulator after the pressure switch, right from the manufacturer. Neither of my Ingersols had the regulator though...
   / Need Air Compressor and Bench Grinder advice. #59
If you don't turn the adjustment knob to change the regulated pressure fairly often, you have problems with it when you need it the most. When I had a 60 gallon compressor, I had a regulator I could take apart, clean, and re-install. And with the 30 gallon compressor I currently have, the regulator died recently, so I bought a new one. But instead of installing it in the usual way, I put quick connectors on it, and of course have a quick connector at the compressor so I can unplug the hose and put the regulator on anytime. But normally I'm just using the compressor's full power of about 150 psi without the regulator being inline.
I may put a t in line, so I'll have the reg on one out put and a full power port. I use 1/4 NPT Fittings, but the threads off of the compressor ball valve is 3/4 Thread I think.
2014 Ford Taurus (A56859)
2014 Ford Taurus...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
