Need aftermarket bucket cylinder for a LA723 loader
   / Need aftermarket bucket cylinder for a LA723 loader #1
Paul12210
Lower Alabama
Kubota 3430 / JD 5103
Does anyone know of an aftermarket hydraulic cylinder that will fit the Kubota LA723 FEL? I'd like to not have to spend $800+ for the OEM part. The part number is 7J267-64010 which appears to have been replaced by part #7J291-64010.
   / Need aftermarket bucket cylinder for a LA723 loader #2
Have you thought about taking it to a hydraulic repair shop? Likely they can fix it, but if not, they can pull a replacement off the shelf and give you a price.
  • Good Post
Reactions: JWR
I stripped the nut off the shaft. Price for just that is 75% of the cost of a new cylinder. Thanks.
   / Need aftermarket bucket cylinder for a LA723 loader #4
Put the nut on and weld it. What is there to loose? Second option a machinist could either weld up the treads and re thread it or re thread it a little bit smaller.
We welded it yesterday. It popped off the first time I tried to use it.
   / Need aftermarket bucket cylinder for a LA723 loader #6
Did you have it adequately cleaned and weld it hot enough? Also some nuts have a coating that needs ground off.
2008 Ford F-450 Crew Cab Service Truck (A55973)
2008 Ford F-450...
2023 CATERPILLAR 259D3 SKID STEER (A52707)
2023 CATERPILLAR...
UNUSED IRANCH 8" MINI EXCAVATOR BUCKET (A57193)
UNUSED IRANCH 8"...
BRADCO HP600 HYD COLD PLANNER (A52707)
BRADCO HP600 HYD...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
