Need aftermarket bucket cylinder for a LA723 loader
   / Need aftermarket bucket cylinder for a LA723 loader #1
Paul12210
Lower Alabama
Kubota 3430 / JD 5103
Does anyone know of an aftermarket hydraulic cylinder that will fit the Kubota LA723 FEL? I'd like to not have to spend $800+ for the OEM part. The part number is 7J267-64010 which appears to have been replaced by part #7J291-64010.
   / Need aftermarket bucket cylinder for a LA723 loader #2
Have you thought about taking it to a hydraulic repair shop? Likely they can fix it, but if not, they can pull a replacement off the shelf and give you a price.
  • Good Post
Reactions: JWR
I stripped the nut off the shaft. Price for just that is 75% of the cost of a new cylinder. Thanks.
   / Need aftermarket bucket cylinder for a LA723 loader #4
Put the nut on and weld it. What is there to loose? Second option a machinist could either weld up the treads and re thread it or re thread it a little bit smaller.
We welded it yesterday. It popped off the first time I tried to use it.
   / Need aftermarket bucket cylinder for a LA723 loader #6
Did you have it adequately cleaned and weld it hot enough? Also some nuts have a coating that needs ground off.
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
2016 International WorkStar 7400 21ft Cylinder Pallet Flatbed Truck (A55852)
2016 International...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 Skytrak 10054...
2017 FORD F550 XL SERVICE TRUCK (A57192)
2017 FORD F550 XL...
1992 Ingersoll Rand (A55973)
1992 Ingersoll...
