Need aftermarket bucket cylinder for a LA723 loader
   / Need aftermarket bucket cylinder for a LA723 loader #1
Paul12210
Lower Alabama
Kubota 3430 / JD 5103
Does anyone know of an aftermarket hydraulic cylinder that will fit the Kubota LA723 FEL? I'd like to not have to spend $800+ for the OEM part. The part number is 7J267-64010 which appears to have been replaced by part #7J291-64010.
   / Need aftermarket bucket cylinder for a LA723 loader #2
Have you thought about taking it to a hydraulic repair shop? Likely they can fix it, but if not, they can pull a replacement off the shelf and give you a price.
  • Good Post
Reactions: JWR
I stripped the nut off the shaft. Price for just that is 75% of the cost of a new cylinder. Thanks.
   / Need aftermarket bucket cylinder for a LA723 loader #4
Put the nut on and weld it. What is there to loose? Second option a machinist could either weld up the treads and re thread it or re thread it a little bit smaller.
We welded it yesterday. It popped off the first time I tried to use it.
   / Need aftermarket bucket cylinder for a LA723 loader #6
Did you have it adequately cleaned and weld it hot enough? Also some nuts have a coating that needs ground off.
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A56858)
2006 Chevrolet...
TANK MANIFOLD (A55745)
2019 GALYEAN...
Generator (A55973)
Generator (A55973)
PULL BEHIND SHEEP FOOT COMPACTOR (A52707)
PULL BEHIND SHEEP...
