Need aftermarket bucket cylinder for a LA723 loader
   / Need aftermarket bucket cylinder for a LA723 loader #1
Paul12210
Lower Alabama
Kubota 3430 / JD 5103
Does anyone know of an aftermarket hydraulic cylinder that will fit the Kubota LA723 FEL? I'd like to not have to spend $800+ for the OEM part. The part number is 7J267-64010 which appears to have been replaced by part #7J291-64010.
   / Need aftermarket bucket cylinder for a LA723 loader #2
Have you thought about taking it to a hydraulic repair shop? Likely they can fix it, but if not, they can pull a replacement off the shelf and give you a price.
  • Good Post
Reactions: JWR
I stripped the nut off the shaft. Price for just that is 75% of the cost of a new cylinder. Thanks.
   / Need aftermarket bucket cylinder for a LA723 loader #4
Put the nut on and weld it. What is there to loose? Second option a machinist could either weld up the treads and re thread it or re thread it a little bit smaller.
We welded it yesterday. It popped off the first time I tried to use it.
   / Need aftermarket bucket cylinder for a LA723 loader #6
Did you have it adequately cleaned and weld it hot enough? Also some nuts have a coating that needs ground off.
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
A & B 5' 3pt Blade (A50121)
A & B 5' 3pt Blade...
Cushman Electric Golf Cart (A50121)
Cushman Electric...
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
