NEED ADVISE & SUPPORT
/ NEED ADVISE & SUPPORT #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Managed to crack rear axel housing on 3400 HST and now need to replace.
1. Can one side only be removed?
2. Other than axel oil seal and housing, any other parts required?
3. Parts list dosn't show gasket and none came with housing?
/ NEED ADVISE & SUPPORT #2
Any chance of getting photos posted of the crack?? Do you know how you broke it? Did a backhoe crack it or something else??
PS sorry I don't know the answer to your questions :confused:
Hit tree limb with rops while mowing (in low range.) Rops bolts to cast iron axel housing and crack is between two upper bolt holes. With advice from TBN think tank I decided against welding crack. Havn't been able to get light right for a useable picture.
/ NEED ADVISE & SUPPORT #4
One side can be removed without having to remove the other, the fit between axle hsg. and rear end housing uses silicone sealer to form a gasket. seal and hsg. should be all the parts needed.
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
CAT D6 SU Blade / Arms (A68134)
CAT D6 SU Blade /...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
More info coming soon. (A64557)
More info coming...
2013 APPCO T-BELT TRAILER (A67714)
2013 APPCO T-BELT...
