NEED ADVISE & SUPPORT
/ NEED ADVISE & SUPPORT #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Managed to crack rear axel housing on 3400 HST and now need to replace.
1. Can one side only be removed?
2. Other than axel oil seal and housing, any other parts required?
3. Parts list dosn't show gasket and none came with housing?
/ NEED ADVISE & SUPPORT #2
Any chance of getting photos posted of the crack?? Do you know how you broke it? Did a backhoe crack it or something else??
PS sorry I don't know the answer to your questions :confused:
Hit tree limb with rops while mowing (in low range.) Rops bolts to cast iron axel housing and crack is between two upper bolt holes. With advice from TBN think tank I decided against welding crack. Havn't been able to get light right for a useable picture.
/ NEED ADVISE & SUPPORT #4
One side can be removed without having to remove the other, the fit between axle hsg. and rear end housing uses silicone sealer to form a gasket. seal and hsg. should be all the parts needed.
(3) Pieces of 30' Sticks of Heavy Wall Poly Pipe (A62679)
(3) Pieces of 30'...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
1062 (A63291)
1062 (A63291)
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
