Need advice please.
/ Need advice please. #1
philshel
Oakhurst, CA
Kioti LK3054
This is a little off topic, but I need some advise on a paint/coating for a project of mine. I’m build new kennels and the materials are galvanized pipe and untreated “hog wire” type fencing. It is all welded together and I would like to paint/coat everything. Ideally one coat is preferred, I would be happy with just a primer coat if I could find something that sticks well and does not cost $200 a gallon.
Thanks,
Phil
/ Need advice please. #2
I've had good results with Rustolium. You can get in gallon cans and paint it on with a brush. The primer would probably work by itself, but I put a finish coat over it. I paint it on so it's nice and thick.
Eddie
/ Need advice please. #3
Rustoleum "hammered" paint, from HD, is ideal for 1 coat over rust; however I don't know if it comes in anything other than spray cans.
/ Need advice please. #4
I use and recommend Rust-Oleum Protective Enamel for all my projects. When it is brushed on and allowed to dry hard, it holds up very nicely and will take some abuse.
/ Need advice please. #5
The galvanized is a problem. I would use something else if you are going to paint them all. You could try to find galvanized wire panels. Then hit your welds with cold galvanized spray. If you just have to paint etch your metal with acid. If it were me I would use a muratic (spelling?) acid solution. Hose off well when done the used the Rust-Oleum primer and paint.
John
/ Need advice please. #6
Wash the galvanized metal with white vinegar before painting and it will stick properly. I agree with everyone about rustoleum. If you prime it first (especially with the heavy rust primer) and then paint you will be in good shape. I have done this with Jeep frames after sandblasting and had great results.
Joe
Ok thanks guys. It appears that I should start with an acid wash and then look at the Rust-Oleum products.
/ Need advice please. #8
Lowe's sells a special "slick finish" primer, recommended by a galvanized metal roof company in Atlanta, for painting their roofs.
832777 (A61166)
832777 (A61166)
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
KUBOTA RTV 900 UTV (A62130)
KUBOTA RTV 900 UTV...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
John Deere 50 (A60462)
Hercules Pesticide Applicator with Nozzle (A61568)
Hercules Pesticide...
