Buying Advice Need advice on tractor
/ Need advice on tractor #1
asylum
There is a Yanmar 187D for sale locally (Western PA). It has a loader and a backhoe. Around 600 hours. The houseing on the transmission is cracked below the driver's seat. So it needs repaired. The guy wants $6500 as is. All works fine except for the repair needed on the transmission case. Is this worth the price?
/ Need advice on tractor #2
that's just insane,.........asylum. Sorry, couldn't resist. But that is a lot of $ for a tractor that size with a cracked housing, in my opinion. Probably caused by the backhoe(?). You should get the extent of damage checked out and determine cost of repair first.
Bill
/ Need advice on tractor #3
If it's the same gentleman I talked to, the case is broken from the stresses of the back hoe. He had a complete replacement parts tractor (in PA?) with a transmission gear problem. The dealer wanted $1800. for it.
I think, unless you are mechanically confident, in no hurry and can negotiate a much better deal, You might just pass this one by.
Yes, I thought he was a little insane on the price as well. I just needed some confirmation.
thanks
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
2020 FREIGHTLINER CASCADIA 116 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2008 INTERNATIONAL 7600 6X4 T/A ROLL OFF TRUCK (A59911)
2008 INTERNATIONAL...
