Citydude
Super Member
Thank you.Thread pruned again...![]()
The premise of your statement is correct, however, to avoid confusion on another topic, I would like to point out that "variable displacement " pumps are only used on closed center hydraulic systems.
Most tractors under 50 hp use open center systems with a constant displacement pump.
Again, just to avoid confusion on a topic that come up frequently.
To reinforce what you said.....
More hydro pedal equals more speed less torque
Less hydro pedal equals less speed more torque.
My throttle is fully open all the time when climbing or bucket work. Also like to mention that the hills that I climb are not straight up from ground level to 1300 ft. There are a couple of flat spots on the hills in between the steep grades which helps the tractor catch up on some speed a little but still takes forever to get to the top.1300 feet up in 1 mile is a 4:1 incline. For every 4' forward you are going 1' up.
A 1:1 slope is 45 degrees, and 100% grade.
A 2:1 slope is 22.5 degrees, and a 50% grade.
A 4:1 slope is 11.25 degrees, and a 25% grade.
That is a very steep angle and grade to try to go up in high range and hold speed.
One thing I didn't see you write was what you are doing with the throttle. Several people asked if you have it at full throttle or not, but I did not see the answer.
that implies the transmission slips. compare that effect to a geared tractor, the transmission don't slip, and just bogs down the engine instead if you're in too high a gear.. automatic transmissions have been designed for decades without slipping but a tiny bit..
Referring to my '98 Terramite T5C, its pump is fixed displacement ie: it has no swash plate, and the Cessna 'torquemotor' is variable displacement/volume.
It should seem perfectly logical that, conversely, a variable displacement pump could drive a fixed displacement motor. (good point, Moss.) I wouldn't be shocked to see both in the same machine.
Once again, we have a reason to expect different performance if machines of similar hp don't use the same system.
btw, Terramite's 'single range' configuration limits ground speed to little more than a walking pace at WOT and 'full pedal' on the HST. Also, its whine can be heard half a block away and sounds like something is terribly wrong. That said, 12 years on mine drives as well as when I bought it.
