Need Advice on Lighting
/ Need Advice on Lighting #1
jc7622
Edmond, Oklahoma
Montana 5740C
I will begin by saying that I am electrically challenged.
I do a some of my tractor work at night and want to upgrade to brighter overhead lights. How do I determine if a particular set of lights will not overload my circuit and blow fuses or melt wires? Do I need to stay below the amps of that particular fuse? Is there any rule of thumb for calculating the potential amps that will draw based on what the light mfgr's wattage?
JC
JC
/ Need Advice on Lighting #3
Watts divided by volts = amps.
You can always go the safe route and power the lights with a relay hooked directly to the battery and fused for the draw the lights will be pulling.
Ken
/ Need Advice on Lighting #4
Ken
/ Need Advice on Lighting #5
Hi JC,
I just upgraded my 5740C front lights to 55 Watt bulbs because the 35's kept breaking the filaments off from vibration. Don't know if anyone else is having this problem? Anyhow, they work just fine and make 1/3 more light. I left the same 10 amp fuse in the block also. I found the bulbs at TSC for $4.40 each. Hope this helps.
JimmyBean
/ Need Advice on Lighting #6
Hi JC,
JimmyBean
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
