Need advice on a larger chainsaw for an older guy.
   / Need advice on a larger chainsaw for an older guy. #11
Well it'll have a 3/8" chain and you'll want it as light as possible yet capable of running a 25"+ bar. Stihl 462 comes to mind, they're light for their size.
About 6 months ago I bought a Stihl 462. I am very pleased with it. Yesterday I bucked up a substantial amount of large limbs and tree trunks-- up to 30" plus but most around 20" or so. Spent several hours sawing and the rest of the day splitting.
I have numerous smaller Stihl saws. But I find the 462 so powerful that it seems to be less effort than a smaller saw since the cut is made much faster. btw I am older than you. Probably similar condition as how you described.
And, I have a Dewalt battery operated chain saw for doing limbing. A small lightweight battery chain saw is very effective and efficient for the kind of work you are going to encounter with your sawmill.
   / Need advice on a larger chainsaw for an older guy. #12
In my experience, felling the trees is the easy part so a heavy saw shouldn't be too much of an issue. Limbing trees is the issue with a heavy saw. I fell my trees with a 60cc saw and limb with a 43cc saw.
I'm 69 years old so walking the log with a heavy saw and a long bar is problematic for me.
   / Need advice on a larger chainsaw for an older guy. #13
I agree. A smaller gas saw for that makes a lot of sense.
  • Good Post
Reactions: N80
I'll have the Stihl Farm Boss and my ancient but runs-like-new homeowner Stihl 025 which is perfect for limbing.
   / Need advice on a larger chainsaw for an older guy. #16
The problem with saw larger than needed for the job isn't when you're bucking in a nice clean wood lot where it's easy to move around and the saw's in wood most of the time anyhow, it's when you have to hike in or put down and pick up and restart the saw a bunch of times while you're moving stuff out of the way. And it's not like it will keep you from working, it will just tire you out sooner. So how much larger is too large kind of depends on the work you're doing and how long you'll be doing it. And of course your strength and fitness. Keeping in mind that when you're tired is when you make mistakes.
You can get milling chain. It cuts a little faster than regular cross cut chain when cutting on the end grain as done in milling. But that's still going to be the slowest cutting orientation. I've not seen it made in safety versions. Since the end of the bar is always out of the wood (the mill has to clamp on both ends of the bar) there's no need.
  • Good Post
Reactions: N80
   / Need advice on a larger chainsaw for an older guy. #17
I've got one. It is great. I've also got files and an electric on bar sharpener. The one you showed is the one I use the most. Quick and easy and does a good job.
Great. Carry on then.
  • Good Post
Reactions: N80
   / Need advice on a larger chainsaw for an older guy. #18
I'm 58 years old and I'm in decent but not excellent physical condition. Average strength I would say.
I am not a chainsaw guy. In other words, I've been using decent consumer Stihl chainsaws all my life but I don't know anything about cc's, chain types, tuning, modding etc etc. Primary use has been yard and property cleanup as well as cutting firewood. I have the proper safety gear and a solid understanding of basic chainsaw safety.
But now I have ordered a saw mill. It should be here in a few weeks. It can handle up to 26" diameter trees.
My primary saw is a Stihl Farm Boss with a 20" bar. I don't remember which one but it is about 3 years old, bought new and was the larger of the Farm Boss saws. In my mind I'm thinking 350 but it might be a 271. I don't even know if the Farm Boss came in a 350. Anyway, it is a decent saw. I suspect it is a consumer level saw with a "farm" designation for marketing.
This weekend I felled several pines that were around 12 inches in diameter. The Farm Boss was okay but not great. I also recently cut up a much larger oak blow down (probably 25ish diameter) and the Farm Boss struggled a lot.
So I am going to be felling larger trees than 12" pines in the near future. My son-in-law will be there most of the time (we'll own the saw mill together). He has a big tuned pro-level Stihl. He has a good bit of felling experience. But I feel like I need a bigger saw for myself. I'm thinking 25-28" bar.
I'm not really looking for brand recommendations.
What I need to know is what I can get for this job that is: 1) Reasonably light. (Again, I'm 58). 2) Appropriately powered for cutting down large but not huge trees. 3) Reasonably safe for my age and experience and 4) What type of chain for my age and experience from a safety vs efficiency standpoint.
Any basic advice much appreciated.
P.S.: Not too interested in modding or tuning a saw.
Just buy a longer bar. My brother has a 5' bar on one of his. You can weld bars together. How you think they cut 11' wide slabs on chain saw mills? The world is your oyster, my friend.
  • Good Post
Reactions: N80
   / Need advice on a larger chainsaw for an older guy. #19
Buy a few new chains, get some different tooth profiles. Se what works best for you. A SHARP chain makes a BIG difference. It could save buying another saw.
But, One saw is never enough!
For felling trees the work will be fairly brief. Drop the tree. Top it. Knock a few branches off. Cut it up into a few lengths. Probably drop no more than one or two trees at any given time.*
The issue with the Farm Boss is that when the bar was fully into the tree on the back cut and sometimes the notch cut it would start to bog and I'd have to reposition, etc etc. (The chain was sharp). That is when the smaller saw makes more work.
*That could change. I have 250 acres of woodland. Probably over 100 of which is in planted pines. We have pine beetles and sometimes they'll die in clumps of 4-5 trees. Up until now I couldn't do much with them. Now that I'm getting a saw mill those dead/dying trees make great lumber...if you catch them early enough. But they go from dying to unusable in a shockingly short period of time. So it might be that my usage will go up.
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
Forklift (A59228)
Forklift (A59228)
1611 (A57192)
1611 (A57192)
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
DEUTZ MARATHON...
