Buying Advice Need a zero turn that doesn't exist?
/ Need a zero turn that doesn't exist? #1
BGRRanch
Longtrac 490
So I have a bit of a situation, and I've googled around, including on here and not come up with a good answer.
I have about 5 acres of Texas hill country that i need to keep grass/bush down on. Its not a lawn, but it is mostly clear. I"m having a dude with a bobcat try to get any remaining debris and most of the sticks/some of the rocks out. But no matter what it will be somewhat rough. If its not mowed the weeds can get up to 4-5', if it is regularly mowed its general native grasses and not that thick. I bought a midsize tractor (longtrac 490 of indeterminate age) and a 5' brush hog and thought that should take care of it.
Except its on a hill. A big scary hill (about 2 acres is just a slope down to the rest). Ive driven my truck up and down it with a trailer, so its not a cliff, but it is TERRIFYING on the big tipsy tractor. I tried once, got a good number of passes done....only being able to remotely steer at the very top and very bottom. Then on a downward run my right tires went into a ditch, my left tire left the ground, I got it out and haven't gone near it with it since.
I hired a guy to bring his old zero turn out, and it actually did manage to mow most of it (pending some areas that needed a bit more bobcat clearing), and it zipped around the hill at all angles with no effort. So my initial thought was to get one and be done with it. Looking specifically at the Cub Cadet SX54 or ZT2 60"...both around $4k. The SX seems better for hills which seems to beat out the slightly more commercial and larger ZT2.
HOWEVER im reading that zero turns arent made for that. Rough terrain will shred them and i can almost guarantee it will hit some sticks and rocks. The guy i hired had to do some repairs to his deck when he was done.
$4k is about the limits of my budget as i was expecting the expensive tractor to handle it.
Is there a low center of gravity brush mower of some type that can handle hills? Will a zero turn get beat up a bit but just need some maintenance and keep chugging? Would the ZT2 handle rough stuff better? How much drop off on hill control would it be?
Is there an option im not thinking of? The hill seems to be severely limiting my options short of some insanely expensive specialty machinery.
Thanks
/ Need a zero turn that doesn't exist? #5
My tractor will go up hills I wouldn’t dream of going up with my truck. It sounds like you should mow it with a tractor and brush hog. I’m not really sure what you bought but there are some things you can do to increase stability, such as fluid in the tires and setting the wheels out wider.
/ Need a zero turn that doesn't exist? #6
Tractors are inherently unstable operating on sloped ground. However, stability can be imporoved.
1) Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability working sloped or uneven ground. A 6" to 10" wider rear wheel/tire spread substantially decreases tractor rollover potential.
2) Filling rear tires 50% to 75% with liquid lowers the overall center-of-gravity for the tractor.
How is your current tractor set up?
What is a Longtrac 490?
/ Need a zero turn that doesn't exist? #7
I would sell your tractor, and purchase a good used high end commercial zero turn. Like a Gravely Proturn or Scag or Hustler. The commercial ZTR can handle the rougher field your throwing at it. And you could always walk the field removing rocks, and flagging any rocks you can't move, and generally improve the field each year for your zero turn mowing. The Texas hot summer will keep the vegetation down until you need to resume mowing again in midSeptember. I think only 6 mowings a year are needed to keep your field looking good.
The second option is like Dodgeman recommended, modifying your tractor to handle slopes with safety, and learn to mow slopes like an expert. This approach is inherently more risky due to stability of tractors on steep slopes. Please Keep yourself strapped in tightly in case it does roll on its side.
/ Need a zero turn that doesn't exist? #8
Ferris commercial w/suspension is a good choice. may consider bar tires instead of turf. once you become a skilled operator, bar tires should not tear up lawn
also consider foam fill ft tires, maybe load rears 1/2 w/fluid. would not foam fill rears, very expensive & prob too heavy for hydraulics
you're going to spend more than 4k unless you want consumer grade crap on the parking lot @ Lowes...wouldn't last long in my application good luck
/ Need a zero turn that doesn't exist? #9
The mower DOES exist, it sounds like what DOESN'T exist, is your wallet fat enough to buy it!!!
4k doesn't buy much these days!!!
SR
/ Need a zero turn that doesn't exist? #11
Hire it out a few times per year. Keep saving some money and increase your budget so you can get into a true commercial machine (ZTR?) at some point.
/ Need a zero turn that doesn't exist? #12
A low end ZT won’t handle hills but a big one handles them fine. Find a used large commercial ZT and put AT101 tires on it.
/ Need a zero turn that doesn't exist? #13
A tractor will work fine , but as others have said it needs to be set up for it 4 wheel drive is a must and an fel or some other front weight helps also. filling rear tires goes a long way also.After 25 yrs of tractor usage i just learned this 3 yrs ago. Now all our tractors have filled rears.
/ Need a zero turn that doesn't exist? #15
This is what I've used for 15 years, Cub Cadet RZT50 with those tires. Yesterday I cut with it for a few hours before the rain.
I cut a hill way too steep to walk up, don't know the grade. I slide way over off seat on uphill side going across topside where it starts to drop off. As I turn going downhill I shift over into seat, going slow as I can. If ground is dry, no problem. Least bit damp you don't have much control...but so low center of gravity doesn't matter. I filled in, leveled depressions years ago. Then at bottom drive around make next pass.
It's 50" cut vs 60" bush hog so not much difference. Then I bush hog the better areas.
Worked well for me all these years, it was $2K new (then).
I'll cut uphill only if it's not too steep, difficult but not impossible walking up. 20200615_104407.jpg
/ Need a zero turn that doesn't exist? #16
These are awesome for slopes but not cheap. Ventrac Compact Tractors & Attachments
Yes I would sell the tractor and buy a Ventrac with whatever attachments you need and take care of your property with it. My friend has one and uses it for all kinds of tasks including mowing, spreading gravel, brush cutting, etc.
/ Need a zero turn that doesn't exist? #17
Rough ground is not that bad on the mower, much worse on the operator, so just go slow. No mower is going to be ok hitting rocks, not even a bush hog behind a tractor, especially large rocks. SO, clean up the rocks, do some rough grading with the Bobcat and then you can mow. If it is rough, just go slow enough that you aren't bouncing in the seat and the mower will do fine.
Rough ground is why I bought my Ferris IS700Z. It has coil spring suspension with shocks on each corner so it really smooths the ride. If I had to buy again, I would add a suspension seat also.
When selecting any mowed get one that is suspended from chains with robust linkage and the rough ground wont affect it too much. Take a look at how the Ferris is built.
/ Need a zero turn that doesn't exist? #18
Thanks
First Off - :welcome: to TBN!
Your budget is a little low to be expecting anything relatively new. Can you post a picture of what kind of location you are dealing with? It might help people to understand your situation better.
/ Need a zero turn that doesn't exist? #19
I believe there is a Ventrac dealer in San Antonio.
/ Need a zero turn that doesn't exist? #20
My Cushman 6150 shown here dirty and when I bought it at Auction, will do circles around the Steiner on Steep Hills on account of it's wide stance. And front wheels being about 16" wide. 10 foot cut, 56 HP KUBOTA 4 cyl, 4WD Sunstrand Drivetrain. . It's ALMOST a ZT and with the wings, goes around trees very nicely. Automotive Steering.
These machines are rated at 80-100 acres in a shift, depending on conditions of course.
A pleasure to use. I always feel like I am flying an airplane. Steiner, terrible operator experience by comparison.
Friends just sold one of these. Didn't know there was such a thing.
216 Hustler(R) Product Video - Super 14 - YouTube
Astounds me though that it's not available in a diesel!
Life is too short to be cutting acerage with dinky equipment!
