need 2120 info
   / need 2120 info #1
jimg
Im looking for info for the title tractor. Ive poked around
online but couldnt find the following:
1) width at the back wheels (r1s are fine)...I assume this is
the widest point. Was it an option to get other than r1s?
3) Is power shuttle only available w/ the 12x12 transmission?
4) Of the 2 transmissions which would be best for all around farm use
12x4 or 12x12? I was thinking about using it as an all around utility
tractor to haul wagons (loaded w/ hay), mow (brush not hay), rake, ted,
load, till (w/ a tiller not a plow).
5) The power shuttle allows you to reverse w/o clutching and before
coming to a complete stop? How is the power shuttle
implemented...eletrically etc?
6) How common are parts? Easy or hard to get?
7) Are there any 'signature' weaknesses w/ the tractor in general?
8) Is the Ford loader frame mounted? Is it quick detach?
9) Whats the lift capacity at the bucket of the Ford loader?
10) Are rear remotes a possibility?
For anyone who owns this tractor what are you using it for? Whats your over all opinion of it? Anything you dont like about it?
   / need 2120 info #2
I've had a 2120 since 1987 with the 12x12 HSS. The transmission is a hydraulic power shuttle. this is definately the best transmission on these models for any use. The 2120 is one of the best tractors that Ford / New Holland made. They are very reliable. It ws available with turf tires also and can be had with industrial tires. The new TC48 and TC55 are basically this same tractor with very few changes except new sheet metal and more hp. Parts are easy to get. No signature weaknesses. The loader is quick attach to a frame mounted subassembly. The lift capacity is about 2000#. I have rear remotes on mine. The power shuttle is a mechanical lever operating a hydraulic clutch pack--no electronics.
I use mine for everything you describe and more. I had a backhoe on it for many years.
Try one you 'll love it. It's quite a step up from the TC45.
Andy
   / need 2120 info
Thanx!
   / need 2120 info
Oh, one more thing that you didnt answer: If you dont mind could you give me a width at the rear wheels? If I trade up for a 2120 Id like to know beforehand which attachments will be too narrow.
   / need 2120 info #5
I don't have my manual here and the tractor is at a job site. I a 60" Bush Hog and the rest of my implements, York Rake and Box Blade are 8'. You might get away with 7' but 6' would be too weak and small. The 2120 is a pretty powerful tractor. It has no problem pulling 8' implements.
Andy
   / need 2120 info #6
For your future refrence the later 2120's had a computer control module for the trans. I think this started around 1997-98 They have been a weak point!
   / need 2120 info #7
</font><font color="blue" class="small">( No signature weaknesses. )</font>
I seem to remember a thread about a year ago concerning the lift arms on the 3PH bending.
</font><font color="blue" class="small">( basically this same tractor with very few changes except new sheet metal )</font>
You mean "sheet plastic", right? /forums/images/graemlins/tongue.gif
I agree with everyone else - the 2120 is a very rugged tractor. It is extremely solid and had a great reputation. The HSS is a pretty cool way of going back and forth. I've sat in the seats of the TC48 and 55 (not driven them, though.) They are a lot more "Boomer"-like, with all the more modern additions like sloping hood, tucked exhaust, etc.
Mark
   / need 2120 info
Andy,
Thanx...I was hoping that I might use my 5' attachments...guess not. BTW have you ever tryed to run a small sq bailer w/ you 2120? It looks like it has enough HP and weight to do the job.
Rick,
Thanx for the heads up on the computer module!! What exactly is the problem? Are they a consumable or do they just not work well w/ the transmission design? Do you have any idea why they were added?
   / need 2120 info #9
So Jim, it sounds like you are getting rid of the TC?
   / need 2120 info #10
The early ones where a problem. Any that we have replaced have been fine since they where replaced with an upgraded module.
   / need 2120 info #11
See the attachment for the 2120 Spec's....
A little fuzzy...let me know if you can't make it out.
Don
   / need 2120 info
Hi Dave,
Yes, Im thinking about it strongly. Not sure where its all going to lead but Im thinking in that direction.
   / need 2120 info
Hi Rick,
Thanx...is there anyway to tell if the module has been upgraded?
   / need 2120 info
Thanx Don,
Where did you find this and is it the offical spec put out by Ford/NH?
   / need 2120 info #15
Comes from my personal Library. /forums/images/graemlins/smile.gif 1996 New Holland - 16 to 47 hp Compact Diesel Tractor Sales booklet. What year is this 2120 your looking at?
Don
   / need 2120 info #16
</font><font color="blue" class="small">( For your future refrence the later 2120's had a computer control module for the trans. I think this started around 1997-98 They have been a weak point! )</font>
spencer
I assume this is when they started having modulated shifting?
Andy
   / need 2120 info #17
</font><font color="blue" class="small">( I seem to remember a thread about a year ago concerning the lift arms on the 3PH bending. )</font>
I seem to recall reading that too. Certainly not the case on my 17 year old 2120. The 3 point arms are very strong and have been worked very hard with 8' 600 to 1200# attachments with absolutely no hint of any bending. If anything I would say they are quite overbuilt.
Andy
   / need 2120 info
Mid 90's w/ a Ford loader. THere dont seem to be that many for sale though.
   / need 2120 info #19
</font><font color="blue" class="small">( Mid 90's w/ a Ford loader. THere dont seem to be that many for sale though. )</font>
Every body I know who has one loves it and just keeps it. My dealer used to have about 25 lease return 2120's available each year. I almost bought a leqse return a couple of years ago for $19,000 with a brand new loader.
Andy
   / need 2120 info #20
I've got one for sale. 1999 2120 770 hrs with NH 7309 loader, 4wd 12x4 trans, aftermarket cab.
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59905)
2021 CHEVROLET LCF...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
