Nearly flipped it
/ Nearly flipped it #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
Well, I was using my new NH TC30 this weekend and nearly flipped it over. I was using the FEL with a chain to lift the front of my 1,200 lb. Zero turn mower so I could clean under the deck. I decided to see how high I could lift it. (7308 loader on TC30 is rated for 880 lbs) I expected the loader valve to go into relief mode when it maxed out. Well, thats not what happened. I was standing next to the tractor as I lifted so I could have a better view of the operation. Suddenly, without warning, the tractor lifted about two feet off the ground in the back and at the same time pivoted toward me on the front axle. Then.....it stopped and just hung there. I let the loader down and decided that maybe the dealer was right when he insisted that these small compacts need loaded tires if you have a FEL. I believe that I will be getting my tires loaded in the near future.
Jerry
/ Nearly flipped it #3
Thats kinda learning the hard way /w3tcompact/icons/shocked.gif but sure glad you came out okay.
/ Nearly flipped it #4
Yeah, it's bad enough when you're on it and belted in.....but next to it.....YIKES!!!!
Jeff
/ Nearly flipped it #5
Wow, Jerry! That sure brings back some painful memories.
I did a very similar thing shortly after I bought my tractor, and wound up starting the infamous <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=safety&Number=22933&page=&view=&sb=&o=&vc=1#Post22933>Stupid Tractor Tricks</A> thread.
"Live and learn", they say. I think that first part is the important one.
/ Nearly flipped it
Harv, thanks for sharing that post. It seems that there is a learning curve for this tractor stuff. Last week I was trying to pick up a dog house with my FEL and ended up pushing it into the side of my garage and tearing up the siding (on the garage and dog house). Weird thing is, I don't even have a dog.
Jerry
/ Nearly flipped it #7
<font color=blue>"Last week I was trying to pick up a dog house...."</font color=blue>
<font color=blue>"Weird thing is, I don't even have a dog."</font color=blue>
Now Jerry, do we really need to offer comments on these statements?? /w3tcompact/icons/hmm.gif/w3tcompact/icons/crazy.gif/w3tcompact/icons/laugh.gif
/ Nearly flipped it #8
I have had the tractor up on 2 or 3 wheels a couple of times, luckily I was in the seat and just lowered the bucket. Now I never try to lift any thing heavier than a few hundred pounds unless I am in the seat.
/ Nearly flipped it #10
<font color=blue>How about posting that attachment again???</font color=blue>
Okay, Wal, here it is. Ain't that much to look at, but it shows how little of a root system it took to dang near topple my L2500DT.
/ Nearly flipped it #11
Its not just the little compacts.
My 70 hp cab tractor gets light in the rear end with a full bucket of gravel.
One solution is a balist.
I use a 1000 lb bush hog since I did not want filled tires.
Fred
/ Nearly flipped it #12
<font color=blue>I have had the tractor up on 2 or 3 wheels a couple of times, luckily I was in the seat and just lowered the bucket.</font color=blue>
Gulp! /w3tcompact/icons/blush.gif First few times are the worst. Its during these initial times that you lose your sanity. Think of it as a new extreme sport (disclaimer - this is not serious, don't do this at home!). A new enhanced version of what we did as kids on motor bikes. How did we ever survive those days. Think I've been getting too used to the 2 and 3 wheel stuff. Two weekends ago must have been on 2 or 3 wheels a few dozen times. Had the box on the back but that clay is just too doggone heavy. Moved around 80 cubic yards of the stuff over 3 days. Still have another 250 to go. Been looking at buying rear wheel weights but will probably just rent a wheel loader (with a 2.5 cubic yard bucket /w3tcompact/icons/grin.gif) and do the job the right way. That piddlin' .75 cubic yard bucket on our tractor just isn't fast enough for the CFO's taste.
/ Nearly flipped it #13
Loaded tires certainly help on my JD4700 and the loader will stall when the static lifting exceeds its capacity without raising the rear when no other impliment is on the 3PH. However, motion, load height, ground level condition and terrain dictate caution, slow and well thought out movements with addition the of weight on the 3PH. Repetitive operations call lull you into a false sense of security so be careful. These accidents typically happen faster than you can correct for them.
/ Nearly flipped it #14
<font color=blue>the loader will stall when the static lifting exceeds its capacity without raising the rear when no other impliment is on the 3PH. </font color=blue>
Even with the rear tires loaded and the backhoe on the back of my Long 360, I can still raise the backend off the ground if I am not careful. The only time I can stall my loader is at very low idle.
/ Nearly flipped it #15
"enough for the CFO's taste. "
Would that be 'chief financial officer' as in 'wife' ?
I call mine 'the treasurer'. I remember when i bought my tractor, I was at the dealership, hammering out some numbers with the salesman... I finally got the ones I wanted to see, and said that I needed to go check with the treasurer.. he said 'yep.. i"m married too'....
Soundguy
/ Nearly flipped it #16
Soundguy,
<font color=blue>Would that be 'chief financial officer' as in 'wife' ?</font color=blue>
Yep. But I gotta keep the rental to a minimum as a large part of the justification for purchasing the tractor was the savings we would have by doing it ourselves. I'm trying to cautiously remind her that it will get done without renting equipment and that the rental is only to meet her timetable. Very touchy subject /w3tcompact/icons/shocked.gif/w3tcompact/icons/eyes.gif
/ Nearly flipped it #17
Just for the record -- when my tippy incident occurred, I had a 5-foot box blade w/rippers on the 3-pt, and my rear tires are loaded. What was missing was my hefty self in the seat.
I think the main problem for me was the fact that I was ignorantly lifting from one corner of the bucket instead of the middle. Rear ballast doesn't help as much when you're trying to tip it over on its side. /w3tcompact/icons/blush.gif
/ Nearly flipped it #18
Harv,
maybe you need some type of heavy outriggers, perhaps retractable so that you can still fit through the narrow places. Perhaps MChalkey can get a thread started on "hydraulic weighted outriggers for lateral stabalization during extreme duty off-center lifting operations" /w3tcompact/icons/smile.gif.
/ Nearly flipped it #19
<font color=blue>maybe you need some type of heavy outriggers</font color=blue>
Believe me, Ron, that thought crossed my mind there for a while, but I've since taken the approach of simply engaging my brain before the hydraulics.
/ Nearly flipped it #20
They already make those retractable outriggers. They call them backhoe stabilizers./w3tcompact/icons/smile.gif
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59908)
2005 KENWORTH T800...
TANK MANIFOLD (A58214)
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
THUNDER CREEK 460 GALLON FUEL TRAILER (A60736)
THUNDER CREEK 460...
