Neal's Generator/Transfer setup
/ Neal's Generator/Transfer setup
Re: Neal\'s Generator/Transfer setup
Purchased the generator from The Power Connection.
http://home.ntelos.net/~gener8s/
2,500.00 delivered to my door.
75.00 for breaker box & breakers.
I had the wire & receptacles & other minor materials left over in obsolete inventory.
/ Neal's Generator/Transfer setup #12
Neal, nice thread. I'll definitely put this info in the book of tricks for future reference.
/ Neal's Generator/Transfer setup #13
Thanks for the link and great pics. I called GenPOwer and was pleasently surprised that their small (12Kw and 15Kw) PTO units are electronic voltage regulator equipped. This gives a voltage control of within 1% from no load to full load. The guy at GenPower really knew his stuff and explained it well. I was looking at the 13Kw unit from Northern and I understand it is capacitor stabilized voltage. Then I called Winco, thinking they would have electronic voltage control-- Nope!, not this small a generator, they are cap stabilized.
Another question I asked was what if I buy "too big" of a generator. The GenPower guy said
""Within reason, no problem. Example, if you have 20 Hp (enough for 10 Kw) but you buy a 15 Kw unit. You will only get as much as your horsepower input allows, so a max of 10Kw. Of course, you choose which loads you allow to run during a power outage situation, so you may only be using 6Kw. If you eventually trade up your tractor to a larger model, your generator will be ready. A bonus of buying a gnerator a bit too big is that it has more rolling inertia and so will start a motor load more effectively without loosing speed (and so changing frequency) with the sudden surge, as much as a smaller generator would.""
They quoted me the following prices for the GenPower units:
12Kw (for 22Hp tractor PTO) $1650
17Kw (for 26Hp tractor PTO) $1750
These are both electronic reg, have both voltage and frequency meters on them, come with 3pt hitch frames, and tumbling bars with gaurds, and ten foot power cordset.
The Northern one was quoted ar $999 without meters, without electronic voltage control, without tumbler bar, and no 3 pt hitch frame or trailer, and no power cordset.
Anyone know where I can buy the GenPower for less money than those prices I wrote here? Thanks!
/ Neal's Generator/Transfer setup #14
What is a "tumbling bar"?
/ Neal's Generator/Transfer setup #15
Tumbling bar = PTO shaft with "U" joints and coupler(s). Sorry, I read tumbling bar somewhere, usually I call it a PTO shaft.
/ Neal's Generator/Transfer setup #16
I never heard of the PTO shaft being called that before. I can almost understand, in a wierd way, how that tumbling bar would fit though.
/ Neal's Generator/Transfer setup #17
I bought the same brand. Seems like they have the best price for the features. I got a 15KW unit. So far it's worked great.
Rich
/ Neal's Generator/Transfer setup #18
Rich, did you buy from the factory? Did you pay the price I posted above (plus shipping of course)? Thanks!
I think they are telling you right about being able to use a unit larger than the tractor. At least to some degree.
When I first purchased mine, I hooked it up to my smallest tractor at the time (770 David Brown) and connected it to a 15 KW electric heat unit. It worked fine with 10 KW turned on, but when I went to 15 KW, it was unable to hold the required speed.
The first time I was using it for backup power and happened to be leaning in the cab of L4610 it was connected to, when the 3 ton heat pump started up, the 23 KW starting load, gave a good jolt to the tractor, but was able to handle it fine.
Jim,
While talking to them, did you find they have models, not shown on their web site or additional models?
While I was looking there, I did not see a 15 KW unit listed and noticed the model 2012 12 KW unit was listed as 3600 rpm rather than 1800 rpm.
Also on that brochure, it did not mention it was solid state controled.
207275 (A52708)
207275 (A52708)
2008 FORD F-550 SUPER DUTY (A60736)
2008 FORD F-550...
2016 FREIGHTLINER  CASCADIA (A60736)
2016 FREIGHTLINER...
(INOP) 1991 GMC DUMP TRUCK (A59823)
(INOP) 1991 GMC...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
