Narrowing Down My Choices
/ Narrowing Down My Choices #1
Hook
Milford, NJ
Kubota L3010
In about 1.5 months we're moving from 0.5 acres to 15 acres. I've been doing lots of research on tractors, but haven't been able to come to a final decision, as I wasn 't familiar enough with the property we're buying.
But I made another trip there today & I think I have a good grasp on what I have to do. I will be mowing about 4 acres on a regular basis. Another 2 acres is pasture, which I'll cut down once or twice a year. About an other acre is brush which I'll probably cut only once/year.
In addition, I will need to be a lot of work on abourt 1 acre of the ground before I reseed it. I'll need to fill some small "ravines", smooth the soil, put some good loam on it, etc.
Here's my thinking about a good tractor for me:
1) I really think the Kubota BX2200 will do all that I have listed above.
2) BUT, I think I should go up a notch, since I'll probably find more to do & I have plenty of space in the barn for a larger tractor.
Currently, I'm thinking of
- Kubota B7500 (or even B2410)
- NH TC21D (or even TC25D)
- Deere 4200
Any comments or suggestions on my thinking & these candidates?
--Hook
/ Narrowing Down My Choices #2
For 15 acres and the kind of work that you've described I think you're going with too small of a tractor. Are you going to be doing any loader work? At a minimum I'd go to the 4400 in deere.
/ Narrowing Down My Choices #3
I agree with cowboy. A BX2200 will be too small. I have three and one half acres and did consider the BX2200, but purchased a JD 4100. I am very happy I did not get the smaller tractor. In fact if you are going to be working 15 acres, the JD4100 might be too small (also the TC21). Although you did not list it, the JD 4200 might be just right, I believe it is similar in size to the TC25. In addition, if you are going to do loader work, the quick attach loader for the Deere is great. I would also recommend HST drive (4wd of course).
/ Narrowing Down My Choices #4
Whoops. You did list the 4200. Cowboy listed the 4400. Certainly the 4400 will do anything you might want. While I think the 4200 will be enough, you can never go wrong with a little more tractor. In any case, I would not want to take care of 15 acres with the BX2200, although it is a neat little tractor.
/ Narrowing Down My Choices #5
I sure do love my 4200 hst.But i would REALY love a 4300!
couple x-tra ponies cheep enough,DEERE rocks!
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A67148)
2024 SILVERBACK...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
Jobox Truck Bed Tool Box (A64556)
Jobox Truck Bed...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
