Box Scraper Narrow box blade
/ Narrow box blade #11
Without a lot of thought, it almost seems like an inclined plate could be welded between two scarifiers with the rear end of the plate resting on the cutting blade.
/ Narrow box blade #12
Or just add wing extensions on a sub spoiler to push the dirt farther away.
Jim.
/ Narrow box blade #13
Jim.
And you've just invented an old V ditcher plow. 3 point v ditcher - Google Search if the link works. I see them a bit on Craigslist & at auctions, but never new. I expect they require a pretty decent machine to pull them. You also end up building berms on each side of your ditch. I suppose that's good for some use cases.
The more modern version seems to be a paddle or drum you spin & just flings the dirt off to one side to create your ditch.
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
405 (A52706)
405 (A52706)
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
