Name this tool #3
/ Name this tool #3 #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
Allright, will probably be easy for this group
Sorry, pictures not the best, Will see if someone recognizes it off the bat before re-doing it.
/ Name this tool #3 #2
Ah that's easy. It's a dead blow hammer :laughing::laughing::laughing:
OK maybe a deburring tool :confused2:
/ Name this tool #3 #3
Used to straighten wire or wind springs. The pictures are pretty rough.
Dan
/ Name this tool #3 #4
well don't know,,but it technical,,hardness tester ???? some kinda tester,,,,
/ Name this tool #3 #8
without zooming in on the pictures, it looked like a parting tool holder. after zooming in, it looks like a butane torch, but backwards.
/ Name this tool #3
Sorry for the bad pictures guys, thought you guys would nail this one fast, but I guess it is not one seen too much.
Hint of the day (along with better pictures)
Think Welding
/ Name this tool #3 #11
This may be a tool to help start wire in to a Mig welder feeder that has run out of wire. For sure it has something to do with Mig wire.
/ Name this tool #3 #12
inside of a wire welding torch handle,looks like tension adjustment screw.Bet if you remove that tape it would help
/ Name this tool #3 #15
Take the dam tape off so we can read whats written.:)
Army Grunt
/ Name this tool #3 #16
I've never seen anything like it here but It looks like something to hold a tig rod and used to feed the rod while tig welding. If it's not it could be :laughing: Nice pictures too :thumbsup:
/ Name this tool #3
Yep, Tig wire (stick) feeder for hand use.
Really helpful to pass the Aircraft test when you need a 6" (I think it was) solid bead with no disruptions in the bead pattern.
Called a Rod Handler made by Tweco.
Have to dig in the boxes a bit and find something else.
Really liked that adapter for the Vise Grips to the slide hammer. Had thought along similar lines but that makes it pretty easy, have to blatantly plagiarize that one :)
/ Name this tool #3 #20
That's pretty cool. Never seen one or ever tried one. I might have to look into getting one :thumbsup:
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2008 THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
2008 THE MACHINE...
EZ-GO Electric Golf Cart (A64912)
EZ-GO Electric...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
