mystery bolt
/ mystery bolt #41
/ mystery bolt #42
The OP said: "It is definitely metric and I don't have a metric thread gauge."
With all the discussion and only one pic I missed what the head markings are, if ever actually reported.
OP's last post was #11. We've all been just guessing with no more that the one pic in post #4.
Myabe he did leave. :confused3:
/ mystery bolt #43
OP should not only look for a missing bolt on his tractor, he should check all the bolts to make sure they are tight.. seems more than one person has had loose bolts.
/ mystery bolt #44
Someone should head over to his place and scatter a few more miscellaneous bolts on his driveway. At least one British Whitworth for good measure.
/ mystery bolt #45
Now that sounds like fun.......
/ mystery bolt #46
As someone who has a set of Whitworth sockets (due to a hydraulic pump that had of Whitworth and SAE bolts), that would be entertaining.
Aaron Z
/ mystery bolt #47
Aaron Z
Wouldnt an English-Metric set cover Whitworth with small enuf gaps?
/ mystery bolt #48
Those '60s Brit bikes were full of Whitworth stuff. Wrench openings were non-standard, and it seems like everything was 26 TPI from 1/4" (rocker boxes) to >1" axles. It's not like everyone doesn't have 21/32" and 25/32" spanners. :)
btw, drill bits come in 'number' and 'letter' sizes, providing < 1/2" increments finer than in 64ths. .003" - .004" size steps and without a quality sharpen most any one you grab will drill that much o'size, esp in a hand-held chuck. ;)
/ mystery bolt #50
I was given some open end wrenches. I found that they had been ground oversize. Someone must have worked on Whitworth stuff.
Bruce
/ mystery bolt #51
I bet the OP is sleeping under the tractor at this point. Looking at every square inch of your equipment can wear a guy out.
Club Car Electric Golf Cart (A64912)
Club Car Electric...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
JCT 72" QA Rotary Tiller (A64912)
JCT 72" QA Rotary...
Electro Magic Hot Wash Cabinet Parts Washer (A66734)
Electro Magic Hot...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
John Deere 6200 Tractor (A64047)
John Deere 6200...
