mystery bolt
/ mystery bolt #41
/ mystery bolt #42
The OP said: "It is definitely metric and I don't have a metric thread gauge."
With all the discussion and only one pic I missed what the head markings are, if ever actually reported.
OP's last post was #11. We've all been just guessing with no more that the one pic in post #4.
Myabe he did leave. :confused3:
/ mystery bolt #43
OP should not only look for a missing bolt on his tractor, he should check all the bolts to make sure they are tight.. seems more than one person has had loose bolts.
/ mystery bolt #44
Someone should head over to his place and scatter a few more miscellaneous bolts on his driveway. At least one British Whitworth for good measure.
/ mystery bolt #45
Now that sounds like fun.......
/ mystery bolt #46
As someone who has a set of Whitworth sockets (due to a hydraulic pump that had of Whitworth and SAE bolts), that would be entertaining.
Aaron Z
/ mystery bolt #47
Aaron Z
Wouldnt an English-Metric set cover Whitworth with small enuf gaps?
/ mystery bolt #48
Those '60s Brit bikes were full of Whitworth stuff. Wrench openings were non-standard, and it seems like everything was 26 TPI from 1/4" (rocker boxes) to >1" axles. It's not like everyone doesn't have 21/32" and 25/32" spanners. :)
btw, drill bits come in 'number' and 'letter' sizes, providing < 1/2" increments finer than in 64ths. .003" - .004" size steps and without a quality sharpen most any one you grab will drill that much o'size, esp in a hand-held chuck. ;)
/ mystery bolt #50
I was given some open end wrenches. I found that they had been ground oversize. Someone must have worked on Whitworth stuff.
Bruce
/ mystery bolt #51
I bet the OP is sleeping under the tractor at this point. Looking at every square inch of your equipment can wear a guy out.
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
2015 Chevrolet Tahoe SUV. (A64557)
2015 Chevrolet...
