MyRide System
   / MyRide System #1
Welshman
Platinum Member
Northeast Ohio
NH T1520
Does anyone here have any experience with Toro's MyRide operator platform suspension system?
I'm looking for a new mower and sat (did not operate) on one that had the system, and it seemed pretty slick, but I'm not sure of the "gimmick factor".
Thanks.
   / MyRide System #2
I own the Toro Timecutter HD with 54inch deck and Myride platform. This is my 3rd year of ownership and I am very pleased with this unit. The Toro was a big upgrade from the Troy Bilt Mustang zero turn that I previously owned. The Toro is heavy duty and has better drive units and higher blade tip speed. It has adjustable road speed and the MyRide system takes the punishment out of mowing uneven ground. It has an adjustment range for the type of ride you want to create. I have not had 1 ounce of problems with this unit. I have added a hitch ball to the back of my Toro and use this for pulling a dump trailer, and sprayer. It has become a workhorse for around the house projects.
Did I say I really am happy with this purchase?
   / MyRide System
Thank you. It sounds as if the MyRide is not just a gimmick.
   / MyRide System #4
I have the TIMECUTTER with 60" deck. Unfortunately, that combination doesn't have the MyRide system available. But when I go over some bumps across the yard, I often wonder how much the MyRide would smooth them out.
   / MyRide System #5
Drive a MyRide and then drive a Ferris with 4 independent suspension. The Ferris is much smoother. I went to a dealership and drove both. There is also a video with a bump course. The rider on the Ferris is smooth vs the harsh ride on the Toro MyRide. Still have my Toro ZMaster 255 and this is the 21st season. Don't know how many more years my back can take it.
   / MyRide System #6
I thought I read something though about the 4 wheel independent suspension causing the cut to be uneven because the suspension is constantly moving the mower deck. Have you heard that?
   / MyRide System #7
If you check out the videos of me mowing on our TIMECUTTER - you'll see that it can be a bumpy ride over some of the areas of the yard. My TIMECUTTER videos are on Purple Collar Life on YouTube.
   / MyRide System #8
I was told this by 2 Toro dealers. The Toro people claim the deck stays more level on the Ferris and scalps small high humps where the Toro rides up and down on small humps. When I watched the video the deck and the rider moved up an down much less on the Ferris going over bumps.
   / MyRide System #9
Thanks.
See if they will let you demo one on your lawn.
When I was in the market for my ZTR I tried the Ferris with IFS and the Kubota motor. I didn't find it any smoother than the Kubota I eventually bought. For me the deal breaker was Ferris cost the same amount as the Kubota but the mower deck was fully manual vs hydraulic on the Kubota. For what they charge on these things I expect a Cadillac with everything to be powered or automatic. My lasting impression is that the Ferris suspension is a gimmick.
I would highly recommend getting an air ride seat if that option is available to you. My OEM seat had a mechanical suspension with 3/4" travel. I installed an air ride grammer seat base with about 2" travel and it really helps reduce the pogo stick action abuse.
A flip up deck would be nice to make scraping and blade changes easier. The older I get the harder it gets for me on my ZD326.
   / MyRide System
Well I bought the Toro Titan with MyRide. It was delivered yesterday in time to cut my grass. I'm very impressed.
I cut grass at my trap shooting club with a zero turn. Part of the property is rutted (as is part of my own yard), and it's brutal to mow these sections. We put a suspension seat on it and it was a great improvement, but the MyRide is significantly better.
Additionally, the cut was beautiful. I'm very happy with it - especially for the price.
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
