My Stupid Problem
Status
Not open for further replies.
/ My Stupid Problem #101
You seem to have a problem with my opinions , Oh well , I'm sure we are from different generations or you would understand my gruff matter of fact posting style .To each his own ,But I have NEVER left a piece of equipment stuck anywhere I would stay with it until it was home or totaled beyond repair and that has never happened , I just can't wait to see the pictures of the 12 ft deep tractor swallowing sink hole . I'm happy for him that it all worked out and it's home safe and sound .
Problem no, you amuse me. Thanks for posting
/ My Stupid Problem #102
I dunno how the **** you were able to sleep leaving it there so long! I can't even sleep now because mines sitting safely at the dealer. LOL Glad to hear it's out, make sure to post pics and a good description!!!
/ My Stupid Problem #103
Hello All,
I wasn't going to post anymore about this, however it was brought to my attention that doing so might be inconsiderate.
A friend and I did get it out today. I'll post the pictures along with the rest of the story tomorrow.
Hurrah!!!! I hope it was easier than it looked. Is there a U tube video?
/ My Stupid Problem #104
I'm cautiously happy for you DT.. I hope it all came out intact.
/ My Stupid Problem #105
Glad you got it out and looking forward to some photos. My advice would have been to use explosives, not because that is practical but because it would have made the news and made some great photos.
/ My Stupid Problem #106
Check list for GOM, luggage,water & a sleeping bag attached to all of my equipment.LOL.Glad to hear you got it out DT.coobie
/ My Stupid Problem #107
He wouldn't need any of that Coobie. He would live off the land.
Sent from my Samsung SPH-L710 using TractorByNet
/ My Stupid Problem #108
Any problem on Earth can be solved with the careful application of high explosives.
Colonel Mertz von Quirnheim
/ My Stupid Problem #109
Quoted from Gumpyoldman: "...I have NEVER left a piece of equipment stuck anywhere I would stay with it until it was home or totaled beyond repair and that has never happened..."
So if there were no cell service and no sat phone within reach you would hunker down and go without food or water to keep your tractor company while you singlehandedly figured out how to rescue it by yourself or used your 'C-4' filled backpack to blow it to smithereenes?!:confused2::eek:
Is this your matter-of-fact solution to all things tractor related? your way or the highway, Sarge?:rolleyes::D
The OP is lucky he didn't walk the property in advance, in this situation, and his method of using his equipment to explore for 'land mines' in this case did do some damage to his equipment, BUT the result is he got to walk away safely. Not a stupid outcome by any means, and he is none the worse of from it, either. Your achtung approach to the same situation would have likely rendered you in the bottom of the ditch/sinkhole with broken bones or dead, which is one step up from grumpy, BTW.
CM out
/ My Stupid Problem #110
It sounds to me like the OP knew what he was doing the entire time, he was just sharing his story more than anything.
/ My Stupid Problem #111
That is what I thought.
/ My Stupid Problem #112
DT, Like everybody else I am pleased you were successful. I am sure that you did in fact know what you were doing, and had an idea of what you might do, but came on here for the opinion of the world at large. There might have been an outstanding suggestion that you had never thought of and you were man enough to seek the opinion of others. There was the usual mix of good and stupid comments, but something that came through in many was the urge for you to stay safe. It was obvious from the way you approached the job that you do that anyway, and yet still you were close to disaster despite your safety precautions. It happens.
Larro Darro, That shovel is a very worn coalfiller's shovel. In low height seams the fillers lay on their bellies and used these shovels to load coal that had been cut out of the seam (various ways including picks) onto a conveyor belt. Legend has it in several pits that the fillers had to take new shovels in the right way up because the seam was too low to turn the shovel over. After the coal had been removed the timber drawers moved in. That is they withdrew the timber pit props and let the roof fall so that there could be no build up of gas. My father did that job, working only night shift (6pm-2am) for over 25 years so that he could run his smallholding during part of each day.
/ My Stupid Problem #113
Kinda sad that this thread has got bad enough that DT didn't want to post back on it. I'm glad the equipment is safe and looking forward to seeing pictures and hopefully reading how it came out.
/ My Stupid Problem #114
Ditto.
/ My Stupid Problem #115
Ditto.
/ My Stupid Problem #116
Thanks for the info. Judging from the website, I thought it must be mine related. My sister's first husband's family were from West Virginia. They had all worked in the mines. They were some tough ones back then. The hardest day on a tractor is easier than being underground. {in the OP's case, he almost did both at the same time}
/ My Stupid Problem #117
LD, Your final remark is funny, and can be said knowing that DT is safe. Father always said that whilst it was bad underground (and in the pit he worked in it went under the sea, so there were doors set that would close if the sea cam in so as not to kill everybody) he would never be a fisherman. Yet there were people who worked with him who went out when they could, just the same as he worked the land. We will never know whether they felt fear but did not show it, or whether they were just fatalistic. If it happens, it happens. Maybe DT has that attitude too - he took care, but accepted that the worst might occur, and as you say, it almost did.
/ My Stupid Problem
Had I known 4 cell phone pictures and a little story would cause such a fuss.....
I had thought about hauling another M9540 up to where the incident occurred but hated the thought of adding another trip with the trailer up and back if it could be avoided. Then while thinking it over I remembered a friend that has a Dairy Farm not far from where I had been working, call him "BR". Monday night I call him, I explained how I was in need of a little help if he had the time to spare. BR was working on his silage trucks between rain showers and could leave any time I came by. Great news, I wouldn't need to call in the National Guard after all.
(BR riding in on his NH TN75)
I left around 3:30pm to head to his place and followed him down the road to the farm. After he looked it over he said the pictures didn't do the hole justice. BR thinks we can simply hook his tractor to mine and force the thing out using brute strength. I didn't think it would work but I was worth a quick try. Just about the time we decide to move on and try something else it begins to rain. Hard.
Now we were on to what was my plan, Plan A.
Unhooking the mower carefully took some thinking. Would I be able get the weight off the hitch pin or will the mower want to keep sliding into the stupid hole? I backed up just enough that I felt the slack come in the hitch, unhooked the hydralics and PTO and pulled the pin with one finger.
Now for Plan A, BR would position his tractor on one side to lift the front end of the machine while on the other side I would lift the rear. As we lift the mower about 2' off the ground we pull backward at the same time about 45 degrees apart the mower will spin 90 degrees towards him. Brilliant.
I reposition my tractor in front of the mower, pulling it by the loader up out of the mud pit and to the barn.
Nothing broke, bent or scratched any more than it already was. But I didn't think it would be.
We talked a while about my stupid hole, farming and bad investments. He mentioned his TN75 was the best tractor he'd ever had. We talked about the differences between sync shuttle and hydro shuttle, wet and dry brakes. When he said it was time for him to leave I offered him money. I had soaking wet bills in my hand (had them in my front pocket during the monsoon) but he wouldn't take a dime. "I might be stuck in a hole one day", he said with a smile. "That's fine, call me, I'll be there." I said.
/ My Stupid Problem #119
Good job and very nice pics!
/ My Stupid Problem
My lap top crapped out this morning so I wrote all of that on my iPhone, took FOREVER!
I now know the reason there is a sink hole, stay tuned I can't write anymore on this tiny screen for a while.
Status
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2023 Kubota M5-091D 4WD 92HP Utility Loader Tractor (A66734)
2023 Kubota...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65056)
2013 VOLVO A40F...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
Unused 2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
PALLET OF FLANGES (A68842)
PALLET OF FLANGES...
