My Snowblower Modifications
/ My Snowblower Modifications #31
Not hard to blow the gearbox if you catch a 4" stone or as I did pick up an old scrap sngine starter that you should not ever left hanging oround.
Sounds to me like its not an blower gearbox issue, but improper shear pins being used...The pins should have sheard off WAY before any gearbox damage. OR using too light a blower for your machine....combined with the Grade 8 shear pins...:rolleyes:
These blowers are built & designed to be "matched"..... just because its XX inches wide doesnt mean anything...for example, the blower I bought has a T60 PTO, Large Gearbox, #60 Chain running the Auger, etc..., you can get the same relative width blower with a T40 PTO Shaft, Smaller Gearbox, and a #50 Chain running the auger...oh yeah, the steel used to build the whole thing is a lighter gauge too...Easiest way to illustrate this would be to look up the specs on a Pronovost Puma 72" vs a 74"....theres more difference then just 2" of width...
/ My Snowblower Modifications #32
Not sure how to start new subject. but...I have a BerVac snowblower. The chute turns via a cable pulley system powered by a piston. One pulley broke-I have replaced the pulley but have no idea how to 'rethread the cable system so it will turn the chute. Any help would be appreciated.
/ My Snowblower Modifications #33
Click on this link, then at the top left, you will see " NEW THREAD" click on it, and you are good to go.
Parts/Repairs - TractorByNet.com
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
