My Septic System Experiment
/ My Septic System Experiment
Just saw this thread. Thx for posting.
I have always loved aerobic systems. They have been around for many years. My folks had one
in central Ohio in the early 70s where there was no leachfield at all, and the effluent from the tank
went out to the storm drain system. It was clear and did not smell much at all.
I have a pump-up septic here that uses Infiltrator chambers and 2 1500-gal tanks. I had the main
tank pumped for the first time after 15y of use. ($450 for one hour's work, no problems, easy access.)
Clearly, that is more than an aerator system could cost, as you have demonstrated. I may
have to install one.
I run a bubbler and vent fan in my 5000-gal water tank to remove sulphurous gases and it has
worked great. Note that an air stone failed there, so I just use a silicone rubber 1/4" weighted line and
an aquarium bubbler.
You definitely want to use a rubber/EPDM diffuser and not stone, since the stone will break down and clog. The EPDM will last a lifetime and never need cleaning.
There's no smell when you open the lid on the tank. It only smells "earthy" as in soil after a rain. The effluent is really clear.
Anaerobic (no oxygen) settic systems put out dangerous gases like methane, sulfur and other toxic gases. The effluent is usually black or brown and clogs the leach field with time. Aerobic (oxygen) systems like mine make a HUGE difference.
/ My Septic System Experiment #62
This is on my "to do" list. I have not decided whether I want to spend the money on a turnkey solution or buy the parts. I know buying the parts will be cheaper so am leaning that way. Keep us informed about the status..
/ My Septic System Experiment #63
PETTRIX: how did you decide on a diaphragm air pump of that size? I just checked the smaller 25 L/min
34W twin of your 40 L/min. Hakko unit. At 24c/KWh, that will cost $6/mo to operate here.
I suspect that a much lower volume of air will also work. I experimented for years with my potable water
aeration/ventilation system before I got it right. My initial design called for a timer, but a lower volume
pump and fan that runs all the time is more reliable and less costly to implement.
I even tried a small air pump that I was hoping I could directly run off a small PV solar panel, without
a battery. No success there.
Since I have a pump-up septic system, I have a 2nd septic tank (aka holding tank) that is also 1500 gallons,
to assure the black water has no solids. The water is actually cloudy and light colored. The pump vault is
installed inside this tank, designed by Orenco Systems.
It's been a few years since my last update. The system is now over 3.5 years+ old.
Still no solids in the primary tank. Effluent is still clear and odorless (besides earthy smell). No issues and the air pump is still going strong with no maintenance except cleaning the air filter on it.
I've cleaned out the effluent filter on the secondary tank and it mainly had an algae like substance on it. No toilet paper or other solids on it. System is great and I am very happy with the results.
Neighbor had to have his septic tank pumped and he paid $550 to do so (1,750 gallon tank). It's expensive out here as they can't dump the sewage locally and must transport it 100 miles away. Not having to pay $550-$600 every few years is a plus with my system.
Thanks for the update. Is your air pump on constantly?
On weekends it runs 24/7 but during the week, it runs from 4pm - 7am.
Eventually I will probably have to replace the diaphragm in the air pump. I think they go for like $50 or so.
/ My Septic System Experiment #67
Nice! Thx for the update.
Last summer, I installed a small aquarium air pump, which runs all the time. I will open up the tank in the spring to see how it looks inside.
I run the Hakko 40L air pump which is good for around 2,000 - 3,000 gallon pond so one would assume that it should suffice for the same size septic tank.
Amazon.com : Hakko Linear Pump, 4 LPM : Pond Water Pumps : Garden & Outdoor
Main thing is to get a good EPDM air diffuser and NOT a stone diffuser as stone will break apart and clog over time. EPDM with PVC pipe is the best.
I ran a 3/4" PVC pipe (rated for 180 psi) from the air pump to the tank (pics on page #1 of this thread). I believe the 40L air pump produces around 10 psi max so no issues there.
/ My Septic System Experiment #69
I did not use an air stone or other diffuser. An airstone clogged up when I tried them in my freshwater tank years ago. I just run the 1/4" poly line on a stainless steel weight right into the water.
/ My Septic System Experiment #70
I just stumbled onto this thread and thanks for posting this Pettrix.
I've had occasional sewage smell in our house since it was first built. I've had the plumbing contractor, who installed the system, out several times to try and find the problem and fix it. 12 years later and the problem still persists, mainly in the colder months. I am going to see if I can find the materials you listed at a local supplier and install this system. You may have made huge improvement to my home without even knowing it.
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
International S1900 (A61307)
International...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A60736)
2014 FORREST RIVER...
