Question about my septic leach field size
   / Question about my septic leach field size #11
Thanks wroughtn_harv; No, I have no problem with the leach field. May have to sell our property due to wife's health. Looking at all papers on septic system including site drawing, perk test, County requirement and final inspection and pictures I took during installation. There were a total of 32 leach panels/chambers placed in 2 separate trenches. Each panel is 8ft long 2ft wide and 1 ft tall. By my figures that is 512 Sq ft. The Sanitation Dept. inspection shows 1500 Sq ft of leach field.
My question is how was that determined. The two trenches were about 3ft wide and shows 30" deep. I don't know how far apart the trenches are.
I apologize for any confusion. Thanks for your input. Red Cox
Read my post above. You either misstated 1500sq feet or they miswrite sq feet. It should be cubic feet. The Infiltrators are rated to “leach” out the bottoms AND sides.
   / Question about my septic leach field size #12
Is/Was there a problem with the old way of doing things?
My old house (built 1937) has a two chamber 'crock' septic tank, 250 gallon capacity the pumper guys have told me. Back in 37 folks probably showered less, washed clothes less, used less chemicals overall, and many things went strait to the leech bed, the gray water, rather thru the tank itself, compared to day. SO I see some changes.
But has there been a problem with the old systems? Is my ground contaminated, the groundwater contaminated, since I don't have all the fancy tech of the new systems? If not, then why the new systems?
There are a lot of environmental problems with the old septic systems including well water contamination, surface/ground water contamination, excess phosphates, etc. There are simply more and more people moving into the country with higher water consumption than ever before...Hence the need for sewage treatment systems. Its the price we pay to live in the country. If you dont like it move into the city and pay someone else to provide you with clean water and to take away and treat your sewage.
Too many city folk simply expect to flush anything they want down the drain and expect it to magically go away.
If you can afford to build a 5000 sq.ft house with 6 bathrooms then you can afford to pay for a sewage treatment system. And you can either learn how to manage it or pay someone to do it for you.
thanks RNeumann. I did re-read your post above and printed it out. The papers provided by the county Sanitation Dept. who inspected the site, checked the progress of installation and final approval of the system plainly shows 1500 SQUARE FEET of leach field. No place does it show CUBIC FEET. You are correct the chambers are designed to leach out the sides and the bottoms. Thanks for your input and have a great 2019. Red Cox
Thanks mikester; Even if you came on sort of strong. Wife & I are age 77 & 78. We don't have a 5000 Sq ft house and we love our 4 acres in the country. We have 1600 sq ft living area, 2 baths and all paper and baby wipes (if used) go into the trash. Water from the washing machine goes into a leach field of it's own. I do treat the septic system regularly with approved treatment. All I did was ask a question concerning how a leach field is sized. We are Christians and worship regularly in our local Church. When I want a sermon I will seek it there. Again thanks for you input. Red Cox
   / Question about my septic leach field size #15
The other requirement is a field replacement area. That could be spelled out in square feet. Can you snap a photo of the paperwork?
   / Question about my septic leach field size #16
if I understand the OP's question correctly a leach field is sized based on the type of soil, the percolation rate found in a test pit dug in that soil, the depth of the water table and the anticipated flow rate from the house which is usually based on the number of bedrooms......so each and every property will have a different set of varying data to plug in to size the system....I've seen property not perc when every other lot around it was fine......there is no standard sized system.......if everything was permitted, inspected, and approved by local authorities and you're not having any issues with it then you should have nothing to worry about.....it only gets complicated and costly if you start having problems with it..........Jack
   / Question about my septic leach field size #17
While you are up there on that big horse's back Mikester,consider this. Here's a quote from a local water district's website." Today, we serve 1.7 million people in about 80 communities in 10 counties, and our region is expected to double in size by 2050." They are permited by Texas Water Commission to by-pass sewage treatment plants to dump raw sewage during peak demand into same lakes from which they pull the public water supply. Never a month go's by when one or more of those communities don't issue a boil water alert. I don't agree with your stance that big shots handle sewage and protect water that much better than rural homeowners.
   / Question about my septic leach field size #18
Why do we have more "exotic" treatment/disposal systems. The bottom line -$$$$$. The companies that mfg these systems are telling developers, politicians, health depts - - "We now have a way that you can develop the lands that were previously deemed unsuitable". OR "This will allow you to get more lots out of your chunk of land than with a conventional septic system".
I went to every weekly planning commission meeting. We had engineers that evaluated proposed development. Their comments were forwarded to the planning commission and made a part of the official record. I was there to expand on our comments and answer questions.
The developers & planning commission didn't like our comments - many times. Many times our comments would say - "poor soils for on-site disposal or no record of adequate quantities of potable water. This went directly counter to the big, splashy promotions and ads.
The Health Dept ran ads in the paper - " get in-writing guarantee of adequate quantities of potable water and suitable soils as a condition of purchase".
It was never any fun telling a new couple that they had just placed a down payment on a piece of land that an on-site sewage permit couldn't be issued on.
OR - they were very unlikely to find water when they had a well drilled.
   / Question about my septic leach field size #19
Well drilling is never a guarantee for anybody and any prospective rural buyer should know that. As for septic systems, it's all about ground water (we often share common underground aquifer "veins"). Probably over-kill in most cases but regulations tend towards a one-size-fits-all meant to address the worst-case scenario. Just the way it works.
   / Question about my septic leach field size #20
Maybe I am dense but the answer for sizing the system has been given several times over. If you aren't trackin OP, you need to start doing some research and understand the regulations that the municipality and the state/ health department has set forth. Pa does not have a health department to over see the installations, jjst the state dep and the local seo. hAve designed septic systems and have had no issues getting them approved, conventional and sand mounds.
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
