My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #421
I used 1/4" thick laminated safety glass - same as a car windshield. The cost was $170.
Thanks. Where did you get it? Do you order it a specific size? Does it require rigid mounting? I ask because I've wanted to put a windshield on my buggy for some time but not sure what direction to go. I've used lexan/Plexiglas in similar situations in the past with poor results. It becomes scratched and hard to see through in short order. Windhield glass is much better in this regard but I am nervous about flex in the fame of the buggy snapping a glass windshield. I know it to be very impact resistant as I've tried breaking a windshield with a hammer before and had it bounce right off, but the flexing is a different thing that I don't know about.
I ordered it from a local glass shop. I made the frame 1/8" larger in all dimensions and just glued it in with RTV silicone rubber.
I picked up the used NV231J transfer case case the other day and promptly disassembled it for inspection after I got home. It appeared to be in very nice shape. I had planned to remove the front output shaft and chain to save weight if I were to install it. As I mentioned in an earlier post, I plan to invert it and use it as a speed increaser (ratio = 2.72:1). I measured it up and modeled it in cad to verify it will fit within my tub frame. The attached image shows what the planned installation would look like. I think it fits nicely. I plan to shift it using a small linear electric actuator hooked up to the shift arm. I measured the required torque to shift it at about 100 inch-#. A few magnetic proximity switches could be used to light up leds on the dash to show what range it was switched to.
Today I started making up the TC support brackets and laid out the planned arrangement of the linear actuator that will be used to shift it. All the parts I need to install it and make it functional are on order. I hope to get it running before the next major snowstorm.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #425
Today I started on the "transfercasearectomy". I pulled out the seats, steering controls and the driveshaft. I then set the transfer case into the approximate location to check for interferences. Over the last few days I mocked up a test harness to check the operation of the linear actuator that will be used to shift the tc gear ratios. Yes, that wiring mess actually works!
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #427
And of course, I am following as to how this latest modification goes. :thumbsup:
I spent the weekend making up the two new driveshafts for the tc installation. Have a looky. The biggest pita was making the jig to align the two shaft ends as shown in the first image. After welding I straightened both driveshafts to about .005" tir. That should be close enough. :thumbsup:
Today I collected the speed changer parts and attempted a dry run before freezing my arse outside installing them. This rats nest worked just fine.
Here's a photo of the installed speed changer setup before I put the floor plates back in. The system works as planned. I hope to take it for a quick test drive before the big storm comes thru Wed.
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
Ryobi BS 900 9" Band Saw (A59076)
Ryobi BS 900 9"...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
1R PLANTER (A52708)
1R PLANTER (A52708)
(INOP) FORD F-700 DUMP TRUCK (A58374)
(INOP) FORD F-700...
