ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 13,500
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
I think your sprockets are slipping because the belt has too much stretch in it. I also think you should make an extra pair of sprockets for each side that helps keep the belt round instead of it going flat between the cross bars as it goes around the sprocket. The pitch between the bars of the belt is changing because the force on the belt is pulling the belt flat between the teeth as it goes around the sprocket. This results in the bar on the belt hitting the tooth half ways up the profile of the sprocket instead of at the root of the tooth where it should be. The noise you hear is the bar on the belt slapping against the sprocket as it slips down the tooth into place. Your drawings show the belt as following the curve of the sprocket but I'm thinking if you watch a video of the rear sprocket you'll see what I mean.
If Garauld already has than much belt stretch,,,, he's got lots of design grief happening. Seems the profile of the cog teeth is not appropriate and he needs to up his belt tension some.
