My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
The blue thing - yes. I plan to use them for dome lights.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #242
What kind of system did they use for steering it? Mine has brake steering.
I spent the last couple of days assembling the grab rails:
View attachment 628988 View attachment 628989
My DIY tractor cab uses the same style of insulation, good thinking.
As to the VW based 'snow machine' they somehow split the differential and inserted a casting that sported a variable drive belt unit very much like snow sleds use.
Never opened it so don't know details.
Steering was by mechanically opening or closing one set of flanges.
It even used the original VW car steering.
Actually every single removable component on a VW chassis was incorporated in that sled machine.
Being designed for Alpine use it had an escape hatch in the cab roof in case of avalanches.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #243
The external grab handle is a nice add-on. Clean.
I spent today setting up a production line for making the track bars and wheel guides. I only need 126 track bars and 252 wheel guides. It is a good task for crappy weather days....
Hi gang - I was playing with a piece of my 5/16" belting trying to home in on a pitch distance for the track bars. I ended up using 84mm (3.307") as a value. I attached a photo of the bars placed around my drive sprocket. Tomorrow, I plan to attach the second 5" belt.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #246
This is the part I've been waiting for!
Are you going to give us a "tour" of your shop?
Not until after I clean it. ;)
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #248
Channel style cleats lost favor some years ago. They fill with ice or mud and loose much of there traction..
View attachment 629988 View attachment 629989
I plan to add a filler strip that will leave a bit of the two sidewalls of each track bar exposed. Also, thanks to ArlyA, I think I will be using his suggested splicing method as shown in my revised design:
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #250
Here is some examples of tire guides. They should be rounded to keep from damage the tires. Turning while on a hard surfaces is really tough on sidewalls. The tires on snowcats are not normal but are commonly foam filled, highly belted and thick treads and side walls. You can still get air filled but most today seem to be foam filled. They live a hard, hard life.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2017 FREIGHTLINER...
2016 Ford Expedition SUV (A56859)
2016 Ford...
